Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 12-02-2009, 07:57 PM   #1
EyeH8the24
EyeH8the24's Avatar
water heater help
got home from work yesterday and had no hot water...heater is about 5 years old .i replaced both elements .now only the top half of the tank gets hot and the pressure relief blows of pressure after just a few minutes ...any ideas ? thanks in advance
DOH !!!!!!!
EyeH8the24 is offline   Reply With Quote
Old 12-02-2009, 08:32 PM   #2
vectorit
What?
vectorit's Avatar
Re: water heater help
Sounds like it's full of sediment.
The new water heaters suck, due to the new energy laws.
If you can do it, I'd check into a tankless type.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 12-02-2009, 08:35 PM   #3
EyeH8the24
EyeH8the24's Avatar
i drained the tank...nothing but water flowed out ..if it had setiment wouldnt some come out of the drain on bottom of the tank and yeah the tankless are awsome just not in my budget righ now thanks
DOH !!!!!!!
Old 12-02-2009, 08:50 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Either the (new) lower element is bad, or there's a problem with its thermostat -- or its wiring. Do you have a multimeter (so you can check voltage)? Can't say why the relief valve is blowing...
I recently replaced a perforated heater that was only about 7 years old. It was a cheap (5 year warranty) heater. I researched a bit and found that heaters with longer warranties use better materials throughout and should last longer.... I ended up getting one with a 12 year warranty.
Just mentioned that in case you have to buy a new heater....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 12-02-2009, 09:46 PM   #5
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Not to completely say your wrong. But atleast with Bradford white heaters that is not right. The only difference between a 12 year and a 5 year is a sticker on the heater and some paper. .....as for the problem I agree with above, check your thermostats.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 12-02-2009, 11:20 PM   #6
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
sounds like thermostats. If you can replace the elements, you can replace the thermostats. We used to loose them all the time in our old house from lightening.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 12-03-2009, 01:48 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Not familiar with Bradford... all that's available locally is Reliance. They have three different lines. Don't recall about the middle-of-the-road 9-year model, but there are significant differences per their specs from their el cheapo 6-year heater to their top-rated 12-year model.
- Mike -
RIP El Jay
Old 12-03-2009, 02:25 AM   #8
79gmcc15
79gmcc15's Avatar
I worked at a plumbing supply company that sold mostly Bradford white, so that's how I know. I think we only sold a few of reliance tankless. Other then that I don't have much experence with them.
RIP ELJAY
Old 12-03-2009, 02:43 AM   #9
BarryB
BarryB's Avatar
Me too would say, check your thermostats. as for your relief valve. Is it poping off because of the hot water, or just poping off, and the water coming out being colder. I would replace it if its the latter one.
The way a water heater works when it has two elements, the top element will heat until the the top thermostat is satisfied. The bottom element will then kick on until it's satisfied. both of them should never be on at the same time.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 12-03-2009, 07:47 AM   #10
EyeH8the24
EyeH8the24's Avatar
its blowing off very hot water ..even with the temp turned all the way down .im gonna get new thermostats today .thanks for all the help! will let you knw how it goes
DOH !!!!!!!
Old 12-03-2009, 12:10 PM   #11
79gmcc15
79gmcc15's Avatar
You may know this or not but there is a difference between the upper and lower thermostats. So make sure you get one lower and one upper.
RIP ELJAY
Old 12-05-2009, 03:46 PM   #12
EyeH8the24
EyeH8the24's Avatar
ok new elements...replaced both thermostats and its doing the same thing ! !! cold on the bottom hot on top and still blowing off pressure ????!!!!!!!!
DOH !!!!!!!
Old 12-05-2009, 05:07 PM   #13
leddzepp
Moderator
leddzepp's Avatar
x 2. It is full of sediment. You need a new one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-05-2009, 05:09 PM   #14
EyeH8the24
EyeH8the24's Avatar
just got back from home depot ..changed out the relief valve and all seems well.....!!!!
DOH !!!!!!!
Old 12-05-2009, 05:27 PM   #15
leddzepp
Moderator
leddzepp's Avatar
Sweet!!!
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-05-2009, 05:36 PM   #16
EyeH8the24
EyeH8the24's Avatar
thanks for all the help !!!!
DOH !!!!!!!
Old 12-05-2009, 06:17 PM   #17
big mike71
big mike71's Avatar
I had too much water pressure coming into the house that caused my relief valve to blow, so I had to get a pressure reducer,
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
