Old 12-12-2009, 10:56 AM   #1
lowhoe
Swapping 6 lug rear on a 85
Im looking to convert my 85 to 6lug. I already have the front end taken care of thanks to early classic. For the rear I have come across a 6 lug rear with dics that has already been narrowed 4.5" per side. I plan on running a 24"x10" wheel with either a +12 or +32 offset. I know the 6 lug rear before being cut is alittle wider than the 80's model rear. Im just worried that the 6 lug rear being cut 4.5" per side might be a little to narrow even with running a 24"x10". Anyone have some exsperience with this situation, or know how much wider the 6 lug rear is than the 80's model rear? Any info would be a help.
lowhoe is offline   Reply With Quote
Old 12-12-2009, 11:20 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Swapping 6 lug rear on a 85
Can't you just measure the differnce between the "narrowed" 6-lug rearend and your stock 5-lug rearend? (total width)
Keith
Convert to disc brakes.
Old 12-12-2009, 11:31 AM   #3
lowhoe
ya i could but the guy who has the 6 lug rear is out of town for a few days so he isnt around to give me the lengh measurments so i figured i just ask
Old 12-12-2009, 12:08 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
What year is the 6 lug rear?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-12-2009, 01:32 PM   #5
Damien
Damien's Avatar
Pull the axle shafts from a 4x4 10 bolt rear and stick them in your housing. Six lug, cheap.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 12-12-2009, 02:39 PM   #6
lowhoe
Ya nevermind the guy wants way to much for the rearend
Old 12-12-2009, 02:41 PM   #7
lowhoe
I was told that the splines and the axle shaft lenghs were different. Anyone know for sure?
Old 12-13-2009, 03:13 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
Get the drums too
Old 12-13-2009, 11:05 AM   #9
68 TT
Still plays with trucks
68 TT's Avatar
If the six lug axles are from a square body 8-1/2" 10-bolt they will fit with no issues.
The new body style trucks got a spline change in their 8-1/2's up to 30-spline and they are a little wider, plus the housing brackets are different.
With what you want to run I would stick with the square body rear end.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 12-13-2009, 12:24 PM   #10
lowhoe
So as Damien said, as long as find 4x4 10 bolt square body axles, the shaft lengh and splines should all be the same correct?
Old 12-13-2009, 01:22 PM   #11
lowhoe
From info i found on the net the only difference i found between the 4x4 and 2wd axles is that the 4x4 axles is 31 5/16" in lengh and the 2wd is 31 3/8 in lengh. Thats only a 1/16 difference between the two axles.
Old 12-13-2009, 07:55 PM   #12
lowhoe
bump
