![]() Join Date: Nov 2009
1985 k20 rear brake question
i just put my newly bought 85 k20 on the lift to do some work and saw this thing hangin off the frame in the rear and im not sure what it is.there is a bracket mounted to the frame with a thing on the end that the rear brake line runs into then back out to the rubber line that tees to the right and left brakes it also has a lever that moves that is bolted to the rear end,what is this thing?thanx for the info
Re: 1985 k20 rear brake question
its called a load bias valve. it reduces brake preasure when there is no load in the bed to keep you from skidding the tires.
either tie it up or take it out. |
3/4 Ton Rodder
Is there a chance that it could malfunction during the winter? I keep skidding my rears all around town until the brakes are pumped a few times.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD 1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy. |
thanks for thefast response,so i take it i can eliminate it
if it fails it is only going to give you 100% of the avialable braking power. if you keep sliding around you need to look at your pads, get new tires or quite driving to fast for conditions.
:guilty of all three: yup, get it out of there, 90% of the trucks on the road dont have them at all. i am surprized to see that yours is a 3/4t, i have only seen them on 1t chevys. |
thanks guys tonite i am taking it out.
