Rear end swap question
My question is will the rear from an 88 s10 4x4 blazer bolt into a 95 s10 4x4 pickup, assuming they have the same gear ratio?
67 Chevy K20 LWB Fleetside project 85 GMC K10 High Sierra LWB, 37's, 8 lug rears, 4.10's project 86 m1009 blazer, 6 in lift, 35's, driver 69 c10, 307, long bed, 3 speed, driver 07 Dodge 2500, cc, lb, cummins turbo diesel 00 z28 camaro, ls1, 6 speed, rarely leaves the garage |
blood type; Retumbo
Re: Rear end swap question
I happen to have a 94 S10 4x4 pick-up at work I can measure. spring width, spring spacing, spring length, I can try to get drum to drum as well. this is of course assuming I remember to do this.
blood type; Retumbo
spring center to spring center = 38.5"
backing plate to backing plate = 52" spring width = 2.5" both shocks mounted to the rear of axle on a plate under the springs springs above axle I don't know if I need to measure from pinion to each spring or not. |
Yes it will work. The mounting dimensions are the same.
