Old 12-24-2009, 07:59 PM   #1
kcfirstbuild
Shock Relocaters
Just got myself a 1968 c10 lwb. In the spring I plan on doing alot of suspension work. I want to lower it with Brothers stage two Lowering kit. With 3" front drop springs and 4" rear drop springs. Will I have to use both front and rear shock relocaters or is that not necessary? Or will I run in to any other problems by going with that drop. Any pictures of a 3/4 drop would be great too.
kcfirstbuild is offline   Reply With Quote
Old 12-24-2009, 09:37 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Shock Relocaters
You will need shorter drop shocks and a front end alignment.
Check out www.earlyclassics.com.
I recommend them very highly.
Alot of satisfied ECE customers on here.
Use the "search feature" in the "suspension section" for lowered truck pics.
Old 12-24-2009, 10:41 PM   #3
kcfirstbuild
Oh yeah I forgot to add the shocks - they are included in the kit. Will i need the shock relocaters or no ?
Old 12-24-2009, 11:17 PM   #4
white 67
I dont recommend the shocks from brothers. Mine lasted less than i year and the truck was driven less than 500 miles. There are much better companys than brothers. There stuff costs a little less but you dont save any when you have to do everything twice.
white 67 is offline   Reply With Quote
Old 12-25-2009, 07:56 AM   #5
cdowns
cdowns's Avatar
yes to using rear shock relocators not sure about fronts// i've always went with KBY shocks very good quality
Old 12-25-2009, 08:48 AM   #6
jim zag
ENGINE BUILDER
jim zag's Avatar
I made new upper and lower mounts that stand the shocks up closer to vertical and put the lower mount on the bottom of the plate. This allowed me to use stock length shocks.
JIM ZAG
jim zag is offline   Reply With Quote
Old 12-25-2009, 01:15 PM   #7
kcfirstbuild
So maybe i should go with the 2/4 drop kit from ECE ?
Old 12-25-2009, 02:16 PM   #8
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
If they are selling it as a kit, I doubt it needs a shock relocation kit.
Although more often companies will sell stuff that will technically work just to sell a cheaper setup, but upgrading for improvement is always an option. Adding shock re-locators to improve shock angles on a lowered truck shouldn't hurt.
But I'm thinking the shocks included in the kit will be to short for shock re-locators anyway?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-25-2009, 02:26 PM   #9
byrd
Union Electrician
byrd's Avatar
The shocks you mentioned are made Doestech(sp) and are a really good quality shock, and if they lasted less than a year and the 500 miles you stated, you could have simply called Brothers with your receipt and got a replacement for it for FREE!
Now to what has been asked...
Yes I would use the relocator in the rear for sure and front since you are dropping using all spring.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 12-26-2009, 12:02 PM   #10
kcfirstbuild
So the kit from Brothers is ok Too ?
Old 12-26-2009, 12:24 PM   #11
kcfirstbuild
I Noticed the Brothers kit doesn't come with the shock relocater kit. But the EcE kit does. Now i dont know what to do, which kit. Also not sure which drop to go with 2/4 or a 3/4. Any suggestions.
Old 12-26-2009, 01:14 PM   #12
1restorick
1restorick's Avatar
I would buy the 2"/4" kit. I would also suggest purchasing the kit from Early Classics with the shock relocators and the KYB shocks. They give a nice ride.
My reasons for these suggestion are as follows:
* A 3" front drop using springs alone will limit suspension travel and you will hit the factory bumpstops often.
* The shock relocators are not neccesary for a 4" drop but you will feel a noticable ride improvement with the shock positioned at a better angle.
* ECE's lowering springs are still rated to carry a load. I like to still be able to use my truck as a truck (within reason).
* ECE's kits are very complete with all hardware and they have the best customer service, period!
Just one man's opinion.
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 12-26-2009, 02:48 PM   #13
byrd
Union Electrician
byrd's Avatar
Brothers springs are progressive weight as well. The more you put on them the harder they push back. I have Brothers springs and shocks in my truck and they work great. I have 4" springs and 1.5" blocks in the rear and can still haul what I need(no rock, dirt ect) but furniture and other normal household items are fine....
Zip:40272
Old 12-26-2009, 06:12 PM   #14
kcfirstbuild
ECE wants 112 dollars for shipping holy nuts. Brothers wants 48 bucks whats up with that ?
Old 12-26-2009, 06:21 PM   #15
leddzepp
Moderator
leddzepp's Avatar
I don't know how quickly ECE ships stuff out, or what they keep in stock, but if you buy from Brothers make sure they have it in stock, or you could be waiting a looooong time. The lower price on shipping tells me they are probably going to have it drop shipped from the manufacturer.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-26-2009, 07:36 PM   #16
white 67
If that is the price that there web site says i would be willing to bet that it will be higher after you order. I suggest you call them and get a real shipping price.
Old 12-26-2009, 07:59 PM   #17
chevy_mike
Never Ending Projects
chevy_mike's Avatar
ECE even claims their online shipping calculator is incorrect.
Give them a call and get a real price for shipping.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-26-2009, 08:02 PM   #18
kcfirstbuild
ok good i will
