Old 06-04-2018, 01:44 PM   #1
rdc72
My New Ride
72 454/350/373, PS,A/C, Butternut Yellow.
rdc72 is offline   Reply With Quote
Old 06-04-2018, 01:45 PM   #2
Lanman1972
Lanman1972's Avatar
Re: My New Ride
I like it! More details please.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 06-04-2018, 01:54 PM   #3
rdc72
Re: My New Ride
Thanks, I really don't know a lot about the back ground of the truck, but I have been looking for one for over 25 years, and then you find, then life happens, but I got one know. it has buckets seats, console. vintage a/c, 18/20 wheels, lowered 4 in the front rear unsure? next is relocating the gas tank to the rear and rear disk brakes. has a transmission leak that I nee to address as well. the color is butternut yellow, white top.
Old 06-04-2018, 02:07 PM   #4
jessemthompson
Re: My New Ride
Good looking truck you found. I’m surprised it has a 350 backing up a 454.
jessemthompson is offline   Reply With Quote
Old 06-04-2018, 02:08 PM   #5
hotwls13
Re: My New Ride
Nice Ride! Welcome!
hotwls13 is offline   Reply With Quote
Old 06-04-2018, 02:14 PM   #6
rdc72
Re: My New Ride
Thanks guys, I was surprised myself, most would have a 400, but who knows whats been in this thing? thinking of going with a 700r4?
Old 06-04-2018, 02:16 PM   #7
jessemthompson
Re: My New Ride
If you go 700R4, get two of them. That way you have one waiting to go in after you blow it. You can then rebuild and just rotate them.
Old 06-04-2018, 03:23 PM   #8
rockyrivermark
Re: My New Ride
Man I hear ya. I was ready to pull the trigger then we had twins. That put a hold on everything for a while
Just FYI. I just did the upgrades you are describing
1. I bought a aluminum baffled tank from performanceonline.com
Great tank reasonable price. Doesn't hang way down like the blazer tank does.
2. Got rear disc conversion from little shop manufacturing.
Very reasonable price and works great.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 06-04-2018, 04:32 PM   #9
Jeff's72C10*
Active Member
Jeff's72C10*'s Avatar
Re: My New Ride
Very nice.
Previous C10's
69 SB CST - sold
72 Cheyenne Super LB - sold
Jeff's72C10* is offline   Reply With Quote
Old 06-04-2018, 09:09 PM   #10
wshattuck
wshattuck's Avatar
Re: My New Ride
looks nice... just need some more pics of it!
1969 C10, ZZ502, T400, A/C, WoodBed, Bucket Seats
1965 C10, 5.3LS, 4L60, Vintage Air, Woodbed
wshattuck is offline   Reply With Quote
Old 06-05-2018, 09:35 AM   #11
rdc72
Re: My New Ride
Thanks all, more pics coming soon....Rocky thanks for the info on tank and brakes, really good prices.
Old 06-05-2018, 09:39 AM   #12
hotwls13
Re: My New Ride
Whatever tank you go with, plan it out. If you go blazer tank, you will have to cut bed crossmember, figure out where/how to route the fuel etc etc. My advise would be avoid the blazer tanks and move up to the nicer ones. Lots of guys have put them in (including me), but they have a lot of little "issues" that make them kind of a pain.
Old 06-05-2018, 02:14 PM   #13
Sweeet67
Re: My New Ride
I decided on the Boyds tank. It went in fairly easy, the hard part was the in tank pump, return line, and cutting the hole on the bed. It turned out really nice though and was worth the effort.
Sweeet67 is offline   Reply With Quote
Old 06-05-2018, 02:55 PM   #14
rdc72
Re: My New Ride
Did you pull the bed off or leave it on? I would like to do it with the bed on, but unsure at this point?
Old 06-05-2018, 03:22 PM   #15
rockyrivermark
Re: My New Ride
I have a wood bed and installed mine with the bed on.
Little tricky but can be done.
Precise measuring for filler neck location.
Enough room to tighten filler neck rubber between bed and tank.
The tank from performance online came with a
Metal strap with nuts welded to it.
I drilled 1/2" in frame for the mounting bolts then taped the
Metal strap with nuts on inside part of frame since you can't access it with tank in place.
Make sense? Kinda confusing to explain.
I was going to just drill and tap the frame for the mounting bolts but didn't think the frame material was thick enough to be safe.
Hope this helps.
My build page
Old 06-05-2018, 03:57 PM   #16
hotwls13
Re: My New Ride
My blazer tank required removing the bed. I also have a steel floor.
Previous owner had started the swap so the bed was already just sitting frame/tank when I got it.
Old 06-06-2018, 10:53 PM   #17
Sweeet67
Re: My New Ride
I started the project without pulling the bed. Ended up pulling for ease of completing the project. I don’t have access to a lift and was sick of rolling around on my back. Taking the bed off was a lot easier than I thought it would be. Unhook the tail lights harness and six bolts, then have some meatheads over to help lift it off. Mine is a short bed with steel floor. Two of us could do it, four was a cake walk.
Old 06-07-2018, 12:16 AM   #18
allchevy58
allchevy58's Avatar
Re: My New Ride
Congrats!! Good looking truck.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
