63 c10 rear step notch/new rear clip help
Hello peeps....I want to pretty much lay out the bed.....I have done it before with a huge step notch but that truck had leaf springs, My 63 has trailing arms which you all now hit the frame at one point or another. How low can I go by leaving the arms and using axle mounted brackets for the bags?Any pics of those?I am trying to avoid making a new rear frame piece but is that the only way to lay out?The step notch is around $180 and the metal which I need is half of the price.....any ideas as to whats the best way ?I have done lots of research and browsed through many pics but no close ups or measurements as to the lenght of the cuts,angles, etc. thanks
#2 | |
Re: 63 c10 rear step notch/new rear clip help
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-11-2010 at 07:53 PM. |
low n' slo
![]() Join Date: Mar 2009
wow that looks plenty low. and thats with the stock trailing arms i see. not bad..
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
ok thats sick......Thats good for me....so all i need is the notch...any ideas as to where to find it cheaper?or is it possible to fab something up even though the frame is tappered and not straight...This will be my second DIY bag job. The first was years ago and honestly I forgot what I did. I am on a budget and only want to have 4 switches so a basic set up will do?I want it to drop slow and up faster. What do I need? any ideas are greatly appriciated... Thanks for the quick reply
Porterbuilt Streetrods @ www.dropmember.com
KP Components @ www.cachassisworks.com Suicide Doors @ www.***************** They all offer some sort of DIY step-notch kit for 6x-72 frames.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-12-2010 at 12:22 AM. |
The white truck has 2" blocks on the trailing arms to get it that low. Other than that the rear set up is almost identical to the 2nd pic. As far as making a notch I think it's more cost effective to buy one, the angles are a pita to deal with. Good luck !
Josh Hart High Octane Hotrods 71 C10 Bagged work in progress driver Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=365912 |
#7 | |
Happy to be here
![]() Join Date: Mar 2000
