Old 01-12-2010, 12:22 AM   #1
forestb
forestb's Avatar
New front end for a 62
I'm looking for advice on the best way to convert the front suspension on my 62 from torsion bars to coils. Best meaning simplest, best handling, a bolt on application but not necessarily the cheapest.
forestb is online now   Reply With Quote
Old 01-12-2010, 01:26 AM   #2
Triple6Goat
Triple6Goat's Avatar
Re: New front end for a 62
You can do what I just did and pull a front cross member off a '72 or equivalent year c-10 and bolt it up to your frame. Its not a direct bolt in by any means but its not hard to do and you get coil springs and 5 lug.
everything I used off a '72 are: front crossmember, upper and lower control arms, spindles, brakes, inner and outer tierod ends.
I was able to use the '62 front motor mount for the straight 6, manual steering box with pitman arm, center link (relay rod) and idler arm.
You have to redrill a couple holes in the frame to bolt the crossmember up but I think you use one or two original holes so you can use them as a reference.
1984 C10 swb
1985 K20 longbed 4spd
1977 K10 longbed -SOLD
1962 Chevrolet C10 swb 6cyl. 3spd. -SOLD
Triple6Goat is offline   Reply With Quote
Old 01-12-2010, 01:43 AM   #3
Captainfab
60-66 Nut
You need a complete front suspension from a '71-'87 C10 pickup, C10 Suburban, or 2wd Blazer
Old 01-12-2010, 02:38 AM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Here's a thread that details how to do it with stock parts:
http://67-72chevytrucks.com/vboard/s...d.php?t=366850
And here's another thread on engine and transmission mounting:
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
Old 01-12-2010, 10:50 PM   #5
forestb
forestb's Avatar
Thanks! You guys are awesome.
