Old 10-28-2009, 01:20 PM   #1
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Original 72 model small block engine accesories
Original 350 out of a 72 model truck. I only want to keep the longblock. Selling everything external from the engine.
Right exhaust manifold is bad.
Carburetor, 50 plus shipping
Spark plug wire brackets, 25 shipped
Coil bracket 10 shipped
Accelerator cable bracket 12 shipped
If anyone is interested in any other parts shown, speak up and I will price it here.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-28-2009, 02:42 PM   #2
Primered_69
Primered_69's Avatar
Re: Original 72 model small block engine accesories
Are these the brackets that help kind of hide the wires by wrapping down the back of the engine then over the the plugs. (I know very bad description)
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-28-2009, 02:44 PM   #3
billyecapps
I would be interested in the spark plug wire brackets, if you would throw in the metal down pipe that connect to the bottom of the breather and the piece it connects to on the manifold. Thanks Bill
billyecapps is offline   Reply With Quote
Old 10-28-2009, 03:03 PM   #4
Tx Firefighter
Primered, that's the ones. I can go remove them later this afternoon to get better pics. I will put you first in line since you asked first.
Billyecapps, can't do that deal. I will have to sell the heat tube for another 20.
Old 10-28-2009, 03:15 PM   #5
billyecapps
If Primered 69 passes, I would be interested in the plug wire holders and the heat tube, if that includes the other metal cover it attaches to on the manifold and it is in good shape, for $45.00 shipped.
Thanks,
Old 10-28-2009, 03:24 PM   #6
Tx Firefighter
Very good, let me see what Primered wants to do. You're second in line for the wire looms and 1st for the heat riser. I will keep you updated.
Old 10-28-2009, 04:11 PM   #7
67sss
67sss's Avatar
carb good enough for a daily driver? can you tell me the #'s off of the carb?
67sss is offline   Reply With Quote
Old 10-29-2009, 09:40 AM   #8
Primered_69
If I can still use them with an aftermarket manifold I will take them
Old 10-29-2009, 09:51 AM   #9
Tx Firefighter
Primered has spoken for the wire looms.
Billyecaps, since the wire looms have sold, I can't combine shipping on the heat tube and looms. I'd have to get 25 for the tube and manifold cover, delivered. Are you interested still, at that price ?
67sss, it was a decent runner about 6 months ago. Since removal, the engine has been sitting in my shop as you see it. I will get your carb numbers and post them up today.
Old 10-29-2009, 10:35 AM   #10
driller35
driller35's Avatar
if 67sss passes put me in line, but will also need the carb number
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD
70 Chev CST, 350 auto, PS, PB, AC, tach
driller35 is offline   Reply With Quote
Old 10-29-2009, 11:23 AM   #11
Tx Firefighter
Driller, you're second in line on the carb.
Numbers are:
7043202
J2 @ F8
Old 10-29-2009, 01:25 PM   #12
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Looking at the timing cover and tab, plus oil pan with all hardware. Price and shipping to 32084. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-29-2009, 03:59 PM   #13
billyecapps
Yes, I still want the tube and manifold cover (assuming it is in good shape).
Please pm me, I would like to pay with a postal money order, if possible.
Thanks,
Old 10-29-2009, 06:16 PM   #14
Tx Firefighter
billyecapps, here are the pictures of the parts. There are three pieces, the tube, and two halves of the manifold cover.
I will PM you with my address.
Old 10-30-2009, 12:26 PM   #15
jimer1964
jimer1964's Avatar
kevin interested in fuel line from carb to fuel pump if it is not chewed on to bad shipped to 19320 thanks jim
jimer1964 is offline   Reply With Quote
Old 10-30-2009, 03:09 PM   #16
Tx Firefighter
Jimer1964, I'm at work today. I will look at it tomorrow and let you know on the fuel line.
Heat riser set is sold to Billy Capps.
Primered 69 has the wire looms
D Passmore, I want to keep the pan and timing cover right now. I don't know how long this engine will sit before I build it so I want to keep it oil tight and bug free.
Old 10-31-2009, 05:12 PM   #17
67sss
67sss's Avatar
thanks for the #'s, I'm going to have to pass.
Old 10-31-2009, 05:36 PM   #18
John H.
John H.'s Avatar
valve covers if they are not dented. Temp sending unit if for gauges, engine hoist hooks driver front and pass rear.
John H. is offline   Reply With Quote
Old 11-01-2009, 05:03 PM   #19
driller35
driller35's Avatar
carb is wrong number for me Thanks
Old 02-15-2010, 12:52 PM   #20
roadracer9
Retired from a track near you!
roadracer9's Avatar
TX, Manifold cover, minus the tube, if billyecapps doesn't take it, to 37049 ? Also, steel tube, to vac. advance on distributor ? Thanks
roadracer9 is offline   Reply With Quote
Old 02-15-2010, 02:17 PM   #21
OhOneWS6
OhOneWS6's Avatar
How far from Dallas are you? I may be interested in the carb.
OhOneWS6 is offline   Reply With Quote
