Old 01-28-2010, 11:29 PM   #1
78 Cheyenne
flip kit
im building a 78 c10 longbed and i was wondering how hard it it so install the belltech flip kit. I also wanted to know how it rides.
thanks -ian
78 Cheyenne is offline   Reply With Quote
Old 01-28-2010, 11:34 PM   #2
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: flip kit
A flip kit rides very close to the stock ride. This is because you are using the same suspension. The change in geometry will change it slightly but only slightly. The biggest difference is suspension travel get reduced, hence the notch.
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 01-29-2010, 08:07 AM   #3
MobSled
MobSled's Avatar
Re: flip kit
Just did a home made flip kit on my 77 LWB. Have done the BT flipkits before so its the same thing. You'll get a 5inch drop automatically so that's not bad at all. No need for a c notch. I'm also running dropped shackles which brings me down 6 inches in the back. I am not running a cnotch and have not bottomed out. Make sure you either run drop shocks or oem shocks with shock extenders and remove the oem bump stopps and install the smaller bps. Good luck let's see pics. Nothing better then a LWB on the floor hehe.
MobSled is offline   Reply With Quote
Old 01-29-2010, 08:13 AM   #4
MobSled
MobSled's Avatar
Re: flip kit
Btw man id run oem shocks with shock extenders. I ran drop shocks before and didn't like the ride before, a bit too stiff for my taste aka kidney killer. I switched over to oem shocks and extenders and my ride is still stiff but has a lot of give and take on bumps and potholes. Not to mention shock extenders 50 bucks, drop shocks 50 bucks a piece. Again, good luck.
Old 01-29-2010, 09:48 AM   #5
78-5.3
78-5.3's Avatar
Re: flip kit
i have a LWB with a flip kit ,my truck has the HD leaf springs lowered closer to 6 inches i didnt notch the frame either in the spring ,summer im going to triangular 4 bar my rear so i didnt want to invest anymore money in shock i had a set of front shocks they are shorter in length and smaller in diamiater i relocated the hole in the frame , but as i dont carry weight in the rear so i didnt worry about the smaller diamiater, i wouldnt recomend this for a truck carrying weight and long term use!!!!!
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 01-29-2010, 10:01 AM   #6
thehitchmaster
thehitchmaster's Avatar
Re: flip kit
I just installed one last week. went pretty smooth. They give you a great template. the kit itself is pretty straight forward. I used belltech drop shocks. they seem to work good for me. they are a little stiff, but that doesnt bother me. Ok back to your question. this kit was extremely nice. It installed with no problems, the ride is fine because your not really changing anything. I loved the idea of the "squishy" bump stops rather than the hard eurothane. the only thing i didnt like about the kit was the driver shock mount is to close to the bottom plate for the u-bolts. Not sure what they could have done to avoid this issue. When installing the shock on the driver side, I took the nut from the shock bolt and ground it in half, then installed the shock. hope this helps, hope i didnt confuse you.
thehitchmaster is offline   Reply With Quote
Old 01-29-2010, 11:15 AM   #7
silvereagle07
silvereagle07's Avatar
Re: flip kit
I installed a DJM rear axle flip on my 84. I removed the rear factory bump stops and did not cnotch the frame. I used my factory style shocks and it rides pretty smooth to me. I also carry my Honda Rubicon in the back on a regular basis and it doesn't bottom out.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-29-2010, 11:41 AM   #8
78-5.3
78-5.3's Avatar
Re: flip kit
i tried my factory shocks first they bottomed out on every bump with a hard bang!! and you know i swapped out to front shock i can't tell the differance from the lowered ride to the orginal ride as far as shock ride
Old 01-29-2010, 01:09 PM   #9
jwa76fleetside
jwa76fleetside's Avatar
Re: flip kit
i have a notched belltech flipkit....it rides great
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 01-29-2010, 04:54 PM   #10
MobSled
MobSled's Avatar
Re: flip kit
Shock extenders are the keye, screw the 200 dollar drop shocks just my opinion.
Old 01-29-2010, 05:04 PM   #11
oldschool18
oldschool18's Avatar
Re: flip kit
airbagit.com sells shocks at about every size you want for lowered or raised trucks, on the rear measure where it sits and then get shocks that splits the distance, so if the distance between your mounts is 15" then you would want a shock the will travel 10"-18" or 11"-19" thats just a rough idea or you can go to a NAPA store and they can look up shocks by length if you got a full size truck with a big motor go with the bigest bore you can get or if you are going to carry alot of weight in the bed....NAPA might be alittle cheaper then beltech
oldschool18 is offline   Reply With Quote
Old 01-29-2010, 05:31 PM   #12
3r!c84
Badass
3r!c84's Avatar
Re: flip kit
no i have theses and they work great
http://www.summitracing.com/parts/BEL-8511/
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 01-29-2010, 07:21 PM   #13
78 Cheyenne
Re: flip kit
thanks guys, ill put up some pictures tommorow. where do i go about getting shock extenders?
Old 01-29-2010, 07:29 PM   #14
3r!c84
Badass
3r!c84's Avatar
Re: flip kit
djm makes them.mine came in the flip kit and i never used them
-00 Saturn 5spd
1/4:13:90
Old 01-29-2010, 09:44 PM   #15
MobSled
MobSled's Avatar
Re: flip kit
Yes sir those are also 41 plus tax a piece i`m assuming. Thats 200 for the setup. 2 in the front 2 in the back. You buy shock extenders once for the rear and you slap 15 dollar shocks on there from Autozone or NAPA and they will last you as long as the drop shocks. When time comes to replace the rear shocks you`ll spend 30 plus tax instead of 100 plus tax.
I like the way my rear rides with oem shocks and extenders rather then drop shocks. But then again what the hell do I know right, i`m just a dirty truck driver lol.
Old 01-29-2010, 09:45 PM   #16
MobSled
MobSled's Avatar
Re: flip kit
You can order them from Summit or if you have a hotrod store or any kind of store around you that sells parts for old school cars they should have them. I paid 40 plus tax for mine so dont let anybody screw you.
Old 01-29-2010, 10:24 PM   #17
Panelman55
Panelman55's Avatar
Re: flip kit
Thanks for the info. I pulled my rear end for a refresh and plan to lower by cutting the rear shackles and adding new shocks. i hope to get about 2" out back. I don't know what to do in the front I may cut 1.5 turns off the springs. I don't have the coin to buy drop spindles so I'm not sure how to "get-r-dun" any other way. Give me some ideas.
In God We trust!!!
Panelman55 is offline   Reply With Quote
Old 01-29-2010, 10:57 PM   #18
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: flip kit
Originally Posted by Panelman55 View Post
....I pulled my rear end for a refresh and plan to lower by cutting the rear shackles and adding new shocks......
What do you mean by "cutting the rear shackles"?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-30-2010, 02:54 AM   #19
ShowSS12
ShowSS12's Avatar
Re: flip kit
I have the ebay flip brackets, and I am still looking for a shock. Anyone got any p/n's about some rear shocks you can get at the local parts store
Adam M
STX Designs
Motorcycles | Choppers | Hotrods
ShowSS12 is offline   Reply With Quote
Old 01-30-2010, 03:22 AM   #20
Tow Me
Glen
Tow Me's Avatar
Re: flip kit
I have some shock extenders. PM Me.
Glen Simpson
Severed Ties - Oregon
Roseburg, Oregon
  • 1983 Chevrolet C10 - Ginger
    Photos
Past Trucks
Tow Me is offline   Reply With Quote
Old 01-30-2010, 10:43 AM   #21
Panelman55
Panelman55's Avatar
Re: flip kit
I will remove the leaf springs at the rear shackle. Remove the part that goes from the spring to the bracket on the frame "shackle". cut it in half, add two inches of steel in the newly created opening, weld it up with reinforcement added and reinstall it in the truck( in reverse order as described). I wished I had photos. I will be doing this next week and can post a play by play if you want it.
In God We trust!!!
Old 01-30-2010, 10:48 AM   #22
ShowSS12
ShowSS12's Avatar
Re: flip kit
you know u can buy drop shackles at autozone for like $30.00
Adam M
STX Designs
Old 01-30-2010, 11:02 AM   #23
Panelman55
Panelman55's Avatar
Re: flip kit
Cut and weld is cheep and welding is what I do best. $30.00 Can go to parts I can't make or repair. I'm not cheep, I'm as broke as a snake. I want to make this a nice truck so I can sell for a little coin to feed the kids and pick up another truck and start it over. Keeping them from the crusher, one truck at a time.
In God We trust!!!
Old 01-30-2010, 06:48 PM   #24
78 Cheyenne
Re: flip kit
I just ordered a Belltech flip kit from STILLEN, and it comes with shock extenders.
