1966 c20 rear end wobbles and shakes whole truck when turning in reverse? Help
Got this 66 c20 front end was sketchy at best, new tires and wheel balance has made that better, but when im backing up especially when turning wheel and in reverse whole rear of truck wobbles, shakes whole truck even so have to push gas pedal like going over a large bump? Its wierd. Could it be pan hard bar is not right? Shocks? Rear end. Trucks got some large lowering blocks under the rear trailing arms could this be throwing of alignment of bar? Any help is greatly appreciated. Thanks
Re: 1966 c20 rear end wobbles and shakes whole truck when turning in reverse? Help
sounds like mabe it has a positraction rear and the clutches are binding when turning ?
![]() Join Date: Mar 2013
Broken spider gears? My 77 C20 had that happen...sharp turn and the truck would struggle...forwards And backwards....the broken spiders jammed and created a full locker. lol Another thing to consider could be your brakes are hanging up.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Tags |
c10, c20, rear axle, rear differential, wobbles |
