Old 03-25-2002, 12:42 AM   #1
neonlarry
neonlarry's Avatar
Post Carb and intake instalation ??
Well, I just bought a Holley # 4175 carb with a electric choke from ebay. As soon as I can get a few more things together, I will instal the carb along with a Edelbrock Performer Intake manifold and a HEI distributor. Right now the only question I have is where to hook the wires from the choke and the distributor. I am sure I will have more questions later, but if anyone has any advice now I would appreciate it.
1970 C/10 Light Red 350/350 Dual Exhaust w/Flowmaster 40s
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-25-2002, 01:03 AM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Post
for the HEI run a 10 or 12 gauge wire from the "batt" terminal to the "ign unfused" port on the fuse panel
My Truck pictures
www.xframeimpala.com
68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET"
56 big window short stepside 235 dual 1 brls
64ImpalaSS 327
70 C10 LWB fleetside custom/10 350/TH350
IM me on aol SN= SHAGROLET
68SWB4x4 is offline   Reply With Quote
Old 03-25-2002, 07:14 AM   #3
conman
Post
The electric choke wire needs to come off a ignition "ON" hot wire from the fuse box. I believe the HEI wire should come off the solenoid to the distributor. That way you'll get the 12 plus volts to run in properly.
Fayette Alabama
conman is offline   Reply With Quote
Old 03-25-2002, 08:45 AM   #4
69 longhorn
Post
The HEI wire needs to run to Ign unfused in the fuse box. The yellow wire at the soleniod only provdes 12 volts while the starter is cranking. Also the yellow & white wires can be clipped out of the system.....69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
