Old 02-06-2010, 08:41 PM   #1
70Custom10Nut
70Custom10Nut's Avatar
Question Ongoing brake saga.....
OK, I did all the adjusting and took it out for a test. The truck stops but there seems to be no power assist. When I was bench bleeding the MC I couldn't seem to get the front res to draw fluid. Is this right or did I get a bad replacement? also the pedal is real stiff with hardly any travel. Now everything in the system is new, and in theory it should work. Any insight?
70Custom10Nut is offline   Reply With Quote
Old 02-06-2010, 09:21 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Ongoing brake saga.....
sounds like a low vacum issue...feel the peddle in your DD ( if it has power) with out it running after the second or 3rd press you'll have an Idea of what a no vacum PG feels like
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-06-2010, 09:47 PM   #3
Smallz72project
Smallz72project's Avatar
I concure, sounds like you have an issue in your booster whether it be low vacuum, or just plain bad. Typically if you have a bad MC off the gecko the pedal will just go to the floor or slowly sink (bleed off). Do you have a pretty radical cam in your engine? Perhaps everything is fine and you just arent pulling enough, which in that case you'll have to add a vacuum pump, settle into manual brakes, or swap out your cam.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 02-06-2010, 11:15 PM   #4
70Custom10Nut
I'm running the same setup as always. (no serious cam ) since I got it out of storage I've replaced the entire brake system, MC, booster and all. Now, I have the vacume line going to a fitting on my manifold. Again, I ran this set up before with no problems, and that is what has me confused, In the morning I am going to check to see how much vacume I do have at the hose.
Old 02-06-2010, 11:36 PM   #5
72lb4x4
I got tired of messing with mine and took it to a locally owned shop and had them bleed it after I replaced the parts.
I kept emptying the MC and having to start over.
72lb4x4 is offline   Reply With Quote
Old 02-07-2010, 01:14 AM   #6
hayhauler71
hayhauler71's Avatar
If you have a check valve in your booster hose make sure it is flowing the right way or is not defective.
hayhauler71 is offline   Reply With Quote
Old 02-07-2010, 06:28 AM   #7
cdowns
cdowns's Avatar
do you have a factory service manual to read how to properly bleed the brake system? and to properly do the brake system work?
Old 02-07-2010, 12:24 PM   #8
CCCC
CCCC's Avatar
Based on your description, you may have two problems - so - one at a time. With hard pedal and such effort, it sounds like the booster is not working. If you have good vac to the can, and if the check valve is working properly, either there is a linkage problem (too short) and the booster/diaphragm is not being engaged by the pedal action or there is an internal leak and the diaphragm action is kaput.
Once the booster action is good, try bleeding both front and back sides of the MC while installed - one side at a time. Open the connection a bit at the MC or the prop valve and have someone push the pedal SLOWLY while you look for air/fluid and retighten the connection before they let the pedal up. Leave the top off the MC so you can see any bubbles or turbulence that may occur in there - good way to see if the piston action seems normal. Pedal must be pushed slowly or you will have fluid out the top and on some paint. Keep us posted.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 02-07-2010, 12:32 PM   #9
Hottrucks
Hottrucks's Avatar
good call on the linkage being to long if the MC can't fully disinguage the peddle so that it can take in more fluid ..it will give a hard peddle issue..
one way to bleed is to put a piece of vacum hose on your bleeder and put it in a jar so the other end will be in some fluid..open bleeder slowly push your peddle a coulpe times and then refill the MC and repeat...this is a good way to flush your break fluid and keep it air free
Old 02-07-2010, 09:37 PM   #10
70Custom10Nut
Fixed. It was a bad MC. Is there more than one way to mount the booster bracket? I had someone tell me that I needed to mount mine the opposite to how I have it. so that the MC will sit perfectly level? I know that I put it in correctly, and that I got it out of another 70, besides none of the levers or push rods will line up if I did that. Right?
Old 02-07-2010, 09:41 PM   #11
Hottrucks
Hottrucks's Avatar
pic??
