Old 02-17-2010, 12:12 AM   #1
92470
What is this on the firewall?
92470 is offline   Reply With Quote
Old 02-17-2010, 12:16 AM   #2
92470
Re: What is this on the firewall?
I screwed up and posted this on accident without putting in my real question first. I actually want to know what the metal serrated tab is that is bolted to my firewall on the left of my fuel pump relay. I've seen the same metal tab on other trucks, but nothing is attached to it and I can't find reference to it in any manual. It looks stock, so I'm assuming the factory put it there. Any advice is appreciated. Thanks!
Old 02-17-2010, 12:16 AM   #3
Slofarmtruck
Looks like a grounding point of some sort.
Slofarmtruck is offline   Reply With Quote
Old 02-17-2010, 12:16 AM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
looks like a relay what year is the truck
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-17-2010, 12:17 AM   #5
Slofarmtruck
Wow 3 posts at 10:16!! I had posted the same answer and edited it after I read his updated question.
Old 02-17-2010, 12:18 AM   #6
92470
The truck is a 87'. If you see my post below my original after I hit enter on my original one by accident, you will see what the real question is. Thanks
Old 02-17-2010, 12:21 AM   #7
flamingbig10
6.0 powered square
your second post didn't show up until I posted
Aaron
Old 02-17-2010, 12:23 AM   #8
92470
Yeah, we all fired back within a minute of each other! You guys are faster typers than I am!
Old 02-17-2010, 01:15 AM   #9
Pyrotechnic
Pyrotechnic's Avatar
I had one on my truck in a different spot. That thing was sharp so I just took it off.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 02-17-2010, 01:21 AM   #10
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Could it have been for a second relay to clip on to? Where is Keith when we need him?
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 02-17-2010, 02:36 AM   #11
Stepsideride
its actually a wire loom securing bracket there used to be a plastic ring clamp that would clamp around the loom and then it had a slot that the metal tab slid into the serated edge acted as a grip to hold it like a piece of wood grips a nail.
Stepsideride is offline   Reply With Quote
Old 02-17-2010, 08:44 AM   #12
Keith Seymore
Keith Seymore's Avatar
Geez. Don't you guys sleep?!?
My first thought was "grounding strap" but I like Stepside's answer better. I'll look and see if mine has that when I go back outside.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 02-17-2010, 09:59 AM   #13
James McClure
One shot, one kill.
OH, OH, OH, Mr. Cotter I know what it is. That serated tab is supposed to ground the hood to help RFI interference from the ign reaching the radio antenna in the windshield. I took mine off because it scraped the paint on the underside of the hood support framing. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 02-17-2010, 11:43 AM   #14
Keith Seymore
Yep - that's what I meant by "grounding strap".
K
1979-1986
1986 - 2019
Old 02-17-2010, 12:45 PM   #15
Tony@AirRideTech
Junior Member
We have a winner
Tony@AirRideTech is offline   Reply With Quote
Old 02-17-2010, 08:22 PM   #16
Keith Seymore
Just a followup - my '87 does not have that on the firewall.
K
1979-1986
1986 - 2019
Old 02-17-2010, 10:49 PM   #17
92470
Thanks for all the replies. I would assume that when the hood is closed the metal tab touches the hood, thus grounding it? And it would be serrated to better connect to the hood? Maybe I'm missing something but I would have thought a true strap with enough slack to open the hood that was bolted to the firewall and connected to the hood would have provided a better ground. I know it's a trivial thing, just interesting some trucks have it and others don't in the same year and it's such a strange design for function.
Old 02-18-2010, 02:49 AM   #18
westofb
I really hate wet sanding!
westofb's Avatar
I would think the hinges and hood latch themselves would work to ground the hood! hmmm, hood mounted mercury switched engine bay lights are grounded to the firewall...there maybe holes in my theory!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 02-18-2010, 04:27 PM   #19
loverofchevystrucks
if you are talking about the tab next to the relay its where you attach another relay
loverofchevystrucks is offline   Reply With Quote
Old 02-18-2010, 04:31 PM   #20
Keith Seymore
No - he's talking about the thing shown in the upper left (with the teeth on it).
K
1979-1986
1986 - 2019
Old 02-18-2010, 04:33 PM   #21
Keith Seymore
Yes on both counts.
I have seen vehicles with an actual braided strap (my Chevelle was done that way) - which is probably more effective - but this serrated tab is probably cheaper from a piece cost and labor standpoint.
K
1979-1986
1986 - 2019
