Old 08-15-2002, 04:10 PM   #1
chevjayfsd
Project 7dos
chevjayfsd's Avatar
Headlights
I am wanting to replace my headlights, and i was wondering, is there a special headlight for our trucks?? I want to shy away from the traditional "yellow" color and am looking for some that look like all the mercedes and jags do with the "blue hue" to them. if you know anything about cost and where i can find them it would be greatly appreciated
thanks
jason
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 08-15-2002, 05:26 PM   #2
chevjayfsd
Project 7dos
chevjayfsd's Avatar
ttt
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
Old 08-15-2002, 08:11 PM   #3
Zkast
Zkast's Avatar
The blue color your looking for is called "HID" lights. If you ever have a vehicle with these lights (2001 up GM SUV's and alot of imports) you'll wish it never had them, Not because of the intense light they give off but the $600.00 PER light cost if the transformer ever goes out.
ok enough about that lol... Summit racing sells the Hella light kits that changes a regular size sealed headlight assembly into a newer style reflector light. This style uses the 9004 bulb that you can buy in regular / Ultra bright (white light) / or HID "Look" ( Blueish tint).
Go with the Hella light and a set of ultra bright bulbs.
Zkast is offline   Reply With Quote
Old 08-15-2002, 08:16 PM   #4
XXL
Seņor Member
XXL's Avatar
If you go with the 9004's (or anything more than 55 watts) don't forget to get some bigger wire in there, and relay the power so you don't burn out your light switch and burn your truck to the ground.
Kenneth
XXL is offline   Reply With Quote
Old 08-15-2002, 08:22 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That would suck huh?
Old 01-31-2003, 03:44 PM   #6
Alex Hayley
XXL, could you give a bit more detail(how to do it) about "relaying the power". What is the difference in amps between orginal and "HID" lights?
Alex Hayley is offline   Reply With Quote
Old 01-31-2003, 04:31 PM   #7
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
I assume you're looking for something like this, and they're cheaper than $600
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 01-31-2003, 04:49 PM   #8
smokekiki
Mike
smokekiki's Avatar
Where did you find them? they look pretty cool.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 01-31-2003, 05:02 PM   #9
PloreOSU
To get more power to your new headlights (I think this is what XXL was trying to say), use a relay. The old headlight wires are used across the coils of the relay and therefore don't have to push much current. Use heavy guage cable straight from the battery to the relays to drive the new lights.
72 GMC, 2x4, LWB Fleet
DONE: 2/3 drop, 17" rims, front end rebuild, front/rear sway bars
Working on: old air AC, blazer tank, rear discs, 03 silverado seats.
PloreOSU is offline   Reply With Quote
Old 01-31-2003, 05:58 PM   #10
Church
Carolina Classic Trucks
Church's Avatar
Here is a kit I just came out with. It is a complete coversion kit for the 67-72 Chevy trucks. You do not have to splice any wires.
Just take out your old light and replace them with the new, insert the H-4 bulbs and plug your existing highlight plug back in. In this kit you have a choice of the h-4 regular watt xenon crystal bulbs or the 80/100 watt xenon crystal bulbs.
Here is the post about them and what they look like:
http://67-72chevytrucks.com/vboard/s...=headlight+kit
Church is offline   Reply With Quote
Old 01-31-2003, 07:49 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
www.sylvania.com
Sylvania has some HID lights, plus some less-expensive choices that offer higher output. Check out their website.
Member Nr. 2770
