Old 02-18-2010, 12:48 AM   #1
Slofarmtruck
Rear disc brakes?
I tried the search function already before I get yelled at. Perhaps my key words were incorrect. Regardless, for my 86 C10 I would like to install rear disc brakes. Is there a budget option for this swap, or do I need to purchase a kit from a vendor? I am just wondering if say rear disc brakes from any other GM vehicle will swap onto my rear end? Any and all info with and without pics is greatly appreciated. I don't have my truck out form storage yet, but I know it needs brake work so I figured why not upgrade while I am repairing. Thanks in advance.
Slofarmtruck is offline   Reply With Quote
Old 02-18-2010, 01:03 AM   #2
Dapper Dan
Dapper Dan's Avatar
Re: Rear disc brakes?
I've asked lots of questions around here and have never been yelled at! This is a great place. These are some of the threads I found hope it helps
http://67-72chevytrucks.com/vboard/s....php?p=2988690
http://67-72chevytrucks.com/vboard/s...ar+disk+brakes
Dapper Dan is offline   Reply With Quote
Old 02-18-2010, 02:30 AM   #3
Slofarmtruck
Thanks for the links. Was some good reading. I have a pretty good idea on which direction I will be going now.
Old 02-18-2010, 12:59 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
You can bolt on parts or swap the axel. Caddy and Lincoln full size cars from the 80's have 5X5 bolt patterns. Gear ratios are slightly different too.
http://www.73-87.com/7387garage/chas...n/reardisc.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-18-2010, 07:31 PM   #5
JW76
JW76's Avatar
I am doing a setup from a board member here.... it is a custom bracket from i think captainfab ($75) 77 lincoln rotors ($100) and 80's camaro calipers ($200) then you need the hoses for the calipers. it has an ebrake. with this setup though you need to take about 1/4 inch off the axle flange diameter and also some off the bump out in the middle of the flange that the rim slides on to. it is going well so far.
JW76 is offline   Reply With Quote
Old 02-18-2010, 09:57 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Slofarmtruck View Post
I tried the search function already before I get yelled at. Perhaps my key words were incorrect.....
We try to discourage yelling at anyone around here. Thanks for "trying" to find the correct search criteria.
What plan did you decide to go with?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-18-2010, 10:48 PM   #7
qu1cks1lver56
qu1cks1lver56's Avatar
You know, I never thought about this, but I have an old 77 Lincoln continental doing nothing. It has rear discs on a 9 inch. And coil springs, which I've been thinking about trying to do on my truck anyway. This is getting me thinking that I might need to go snatch that rear end and get to work.
qu1cks1lver56 is offline   Reply With Quote
Old 02-18-2010, 11:25 PM   #8
Slofarmtruck
So far I am leaning towards just picking up the blackbird customs kit as it seems to be a fairly straight forward set-up that will provide me with what I am looking for. I already have a project car so the trucks budget is very limited but than again budgets change based on requirements!
