Old 03-02-2010, 09:36 AM   #1
robby5323
Exhaust on lowered 65 short fleet. Trans crossmember problems...
Down to running exhaust on the truck. I have lowered it enough that the exhaust tubing is going to have to run above the transmission crossmember. Anyone have any pics of this or use that setup on their truck...? Any other ways of routing the exhaust tubing...? I am shooting for just running the pipes straight back and dumping them at the rear. I am using headers and they hang just below the frame rails. I am lowered with cut springs in front (about 4.5" and jeep springs with 2" blocks in the rear).
robby5323 is offline   Reply With Quote
Old 03-02-2010, 12:11 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Exhaust on lowered 65 short fleet. Trans crossmember problems...
Are they a full-length type header with the collectors positioned along side the transmission? I ask because it kind of limits your options.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-02-2010, 02:11 PM   #3
robby5323
Yes, they are the Summit brand G-9006 full length...
Old 03-02-2010, 02:18 PM   #4
d10s69c10
Built 4 Speed
d10s69c10's Avatar
i wish i had a photo of stuff we have done in the past but basicly remove your crossmember. run your exhaust se what kind of space to work with chop out/ cut down the areas where you cannont fit the crosmember and custom build it around your exhaust..
its done with driveshafts all the time around here.. sometimes you can get 4" pipe or bigger the width of the crossmember and weldit in.
i cant write out my thoughts today.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 03-02-2010, 08:58 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
Yes. I did this and routed it thru the driveshaft loop x-member. It's common on these and 67-72's. I used a shorty header so I did not have to offset over the trans mount.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-02-2010, 09:23 PM   #6
vin63
vin63's Avatar
Gotcha...I would probably look into cutting a hole through the trailing arm crossmember on each side to pass the tubing through. You may have to go the route of welding in a larger-diameter tube as d10s69c10 mentioned. This is why I went with a shorty header...I had to route my 3-inch tubing to the outside of the frame.
Old 03-02-2010, 11:45 PM   #7
shortbed70
shortbed70's Avatar
I have block hugger headers on my 65 and I plan on running behind the front tire and turning and mounting the mufflers on the outside of frame and then turning out before the rear tires. I've run my exhaust through the frame on another truck and liked it but there was alot of heat around the trans area so I'm moving it elsewhere.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
