Old 03-07-2010, 07:00 PM   #1
Sillyoldman
#16876
Sillyoldman's Avatar
Quick brake question
I'm on break until the wife gets home before I can make a run to the auto parts store. I put a few new brake lines on today. Even though my bends are not real pleasing to the eye the are free of leaks. After pumping up the pedal I did a quick walk around. It appeared that one of the lines I have not replaced is leaking. It turns out that the fitting that the line goes into is the culpret. I took it apart and cleaned it up and reassembled it. I is still leaking. My first thought is to replace the copper/brass washers to achieve a seal. Am I over looking anything?
Thanks Don
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 03-07-2010, 07:52 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Quick brake question
Is the leak coming from the flare fitting going into the banjo fitting, or is the leak coming from the banjo fitting itself?
For the fittings that use a copper washer, I do tend to use new copper washers since the previous crush on them can sometimes permit leaks if the surface is distorted or uneven, etc.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-07-2010, 08:04 PM   #3
Sillyoldman
#16876
The flare fitting is fine. The banjo fitting is leaking. The washers are not bent up. They are impressed with light rings on one side of each from the original seal. I flipped them but that did not help.
Old 03-07-2010, 09:53 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Those are the things that can drive you nuts. I had the same issue many years ago. Everything looked perfect but leaked. I had spares and did some switching around and it didn't help. Put a new one on that looked exactly the same, and it worked fine. I only hope a new washer fixes your problem.
The other possibility is there's a mismatch in the parts, although this is unlikely if it worked okay the last time it was driven.
Old 03-08-2010, 01:10 AM   #5
Sillyoldman
#16876
I took the banjo off because it appeared to be leaking there. This afternoon I took the part completely off to replace. Turns out the po cross threaded the nut. I don't remember it leaking before. Strange how leaks appear in places other than they appear. I could see it squirt out through the back window as I pumped the pedal. Problem solved. Next step is talking the wife into pumping the pedal for me so I can bleed them. It's going to take a lot of fluid to get the nasty stuff out.
Old 03-08-2010, 09:29 PM   #6
vin63
vin63's Avatar
Unfortunately, the visual appearance is not a good indicator if the copper washer will re-seal - particularly in high-pressure applications. If there is a slight uneveness to either surface/side, and if the fastener is not in exactly the same spot on the washer, it could leak...especially if the fastener is cross-threaded or bent.
