Old 02-02-2003, 10:50 PM   #1
apstguy
LED King
apstguy's Avatar
Reverse sounds and fun with the shifter knob
I have a new question - When I shift in to reverse, it makes a "metalic" noise for about a second. I can't really explain the noise, maybe I'll make a video on the borrowed digital camera to show you the noise.
I had tons of fun trying to get the automatic shifter knob off. Took me about an hour!!! I first tryed to pull it off, but it didn't budge. I took a razor blade to it and cut it all the way down the side. Didn't work. Took a dremel with a cutting wheel to it. Cut it all the way to the metal (oooouuhhhh sparks) and used a screw driver to pull it off.
My observations: It is a vinyl outer piece with a plastic inner. I took the vinyl part off and it had grease like stuff in it. WTF was that doing in there??? This thing is NOT held on my glue. The shaft has splines on the end of it which the knob locks on too. Not fun I tell ya.
Next I installed the billet knob. Push on shaft, turn set screw, then sit back and admire.
Question for all with auto trannys: on the underside of the truck where the shifter connects to the tranny, there is a plastic bearing by where the adjustment bolt is on the shaft that goes into the bracket on the frame. My plastic thinggies won't stay in. It makes it so the shifter can never be calibrated correctly!!! It makes the main shaft loose, is making metal rub on metal, and make it very noisy when I shift. How do these plastic bearings stay in??? Can anyone help me? I may just have to epoxy them.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-03-2003, 12:48 AM   #2
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
On the noise it might be a front pump going out. May be something else though. Is the shifting slow? How long does it take to go into gear?
Gear shift- Been there done that
On the shifter you need a spring to compress the plastic bearing into the bracket where the rod from the shifter goes into.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 02-03-2003, 12:51 AM   #3
79BIG10
79BIG10's Avatar
Look at this.
Old 02-03-2003, 09:23 PM   #4
pkbinplano
pkbinplano
pkbinplano's Avatar
You da man Brandon !
http://www.picturetrail.com/gallery/...7496&members=1
84 chevy silverado aka The Bananna Boat
pkbinplano is offline   Reply With Quote
Old 02-03-2003, 10:17 PM   #5
apstguy
LED King
apstguy's Avatar
On my tranny, I shift ::click:: ::clunk:: in gear. about 1/2 a second to shift. A friend of mine told me these old transmissions have a habit on dieing after changing the fluid. I guess I won't do that any time soon.
Thanks for the info guys! Went to the junk yard today and found the only 81-87 Chevy with a transmission still on it and grabbed the spring from it. I also got air duct hose for the right vent and the cheap metal pipe for the heat riser and brackets from an old oil cooler fron a Suburban. All for $2. Kick Ass!!!
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 02-04-2003, 12:21 AM   #6
79BIG10
79BIG10's Avatar
MIght check the level and color of the fluid. May be time to change it and the filter.
Old 02-04-2003, 01:30 AM   #7
apstguy
LED King
apstguy's Avatar
I'm a little reluctant to do that since my friend says they usually die after you change the fluid. I can't afford that right now.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
