Old 03-21-2010, 10:58 PM   #1
cat72chevy
rear disc
i want to find just the rotors for the rear of my chevy truck its the five on five bolt pattern. I have the calipers and the bracket all ready just wont to know the spot to buy the correct rotors
cat72chevy is offline   Reply With Quote
Old 03-21-2010, 11:32 PM   #2
OhOneWS6
OhOneWS6's Avatar
Re: rear disc
It going to depend on what caliper and bracket you have. A lot of kits use the rear rotors from a mid 90s Impala SS.
OhOneWS6 is offline   Reply With Quote
Old 03-21-2010, 11:34 PM   #3
72swb_327stroker_?
knuckle buster..
72swb_327stroker_?'s Avatar
Re: rear disc
what calipers did you get?
When I pieced my last truck's rear disc conversion together... I got the rear calipers from a 1996 chevy impala ss.
_______________________________________________________________________________
Eric
THIS SITE ROCKS!!!
Check out my suburban on 20's with fresh paint!
Click here to support the site
Check out the Member Photo Gallery here
StreetCruizin
FAQ thread
Site vendors list (scroll down to vendors in red)
join the the smilies fight club
72swb_327stroker_? is offline   Reply With Quote
Old 03-22-2010, 06:28 PM   #4
cat72chevy
Re: rear disc
thank you ws6 i will be going to buy some rotors in a few days, gotta make it before i spend it. And i bought a set of brakets from bluetorch fab. i have used their brackets before and the worked great. They use a factory front disc brake caliper from the c10 the brakets are weld on but i will make little tabs for them to bolt on with so if i have to change the rearend for some unknown reason i can remove them and put them on the next rearend.
Old 03-23-2010, 02:41 PM   #5
cat72chevy
Re: rear disc
ohonews6 the rotors fit perfectly thank u for ur time.
