Old 04-03-2010, 08:15 AM   #1
packers05
Oil pressure gauge line replacement
I would like to hook up my factory oil pressure gauge using a AN type hose and fittings anyone done this do I need any special adapter to connect to factory gauge? I did a search but couldnt find it. It is a 72 K5
packers05 is offline   Reply With Quote
Old 04-03-2010, 10:13 AM   #2
JDL
JDL's Avatar
Re: Oil pressure gauge line replacement
this is will work http://www.jegs.com/i/Auto-Meter/105...oductId=745223
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 04-03-2010, 08:38 PM   #3
packers05
thanks
Old 04-03-2010, 08:56 PM   #4
capev86
just be sure there are no leaks.....rusted pipe or loose connections can slowly bleed your engine dry over time.
i am replacing the line on my 72 burb 'cause it twisted on me today when i removed it from the engine block to make room to clean the deck surface for doing an intake carb swap. going from the stock rochester 2 barrel to an early 80's q-jet on top of an edelbrock (low rpm range) intake.
capev86 is offline   Reply With Quote
Old 04-03-2010, 08:58 PM   #5
Thealien
Thealien's Avatar
OR THIS IS WHAT I AM USING
