body lift question
i have been thinking about putting a body lift on my 1962 chevy c10 fleetside longbox and i was curious if i did would i have to change anything with the steering box?
60-66 Nut
Re: body lift question
You're going to have to install 2 universal joints in the steering column shaft.
where at exactly on the shaft? and would it be possible if i could buy a body lift kit for a 70's or 80's model chevy so i have nylon or polyurethane lift blocks instead of hockey pucks or square tubing?
60-66 Nut
You'll need one at the steering box and another up by the firewall. I don't know if a later model body lift will work since I haven't used one. There are several other things that will need changed as well such as radiator hoses, throttle linkage, clutch and brake lines, trans shifter, etc.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-07-2010 at 01:37 AM. |
I have a body lift kit for a bronco( I know i should not say ford here) that I would take 35.00 plus shipping. I has bolts spacers etc. might work
how sure are you that it would work? and how big of a lift is it?
You can buy individual body lift blocks in varying heights on Ebay for about $5 each.
