Old 04-18-2010, 11:18 PM   #1
low79fx
Changing rod link shift to cable shift on column
Has anyone ever made an attempt to swap their shift linkage to cable linkage like the newer vehicles come with.
Well I just got through converting my 65 GMC from rod linkage to cable linkage and let me tell you it works great. I'll try posting pics later.
low79fx is offline   Reply With Quote
Old 04-18-2010, 11:31 PM   #2
198plus
198plus's Avatar
Re: Changing rod link shift to cable shift on column
I have been thinking of doing that...........Pics would be great.
198plus is offline   Reply With Quote
Old 04-18-2010, 11:40 PM   #3
jmedero
jmedero's Avatar
ill be doing this in the next week or so. Ill make sure to take pics.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 04-19-2010, 10:22 AM   #4
Genuine GM
Genuine GM's Avatar
Yes, very interested!! I was comtemplating buying the kit from Lokar, I never even thought of using what the new vehicles use.
What year donor?
You sir, made my day, subscribed.
Don't let my username fool you, I have become brand blind. Cool is cool, period.
1965 C-10 - "Whipping Post"
1958 Biscayne - "Ruby"
1961 IH Scout 80 - "Gaucho" (My wife's new project)
1938 Chevy - unstarted project.
Genuine GM is offline   Reply With Quote
Old 04-19-2010, 06:13 PM   #5
low79fx
OK,some pics of the install.Hope you can make something out of them.What I used were the cable and trans link bracket and trans cable bracket from a 98 S10 Blazer.The column link bracket and column clamp I fabricated.
Old 04-19-2010, 06:15 PM   #6
low79fx
One more pic.
Old 04-20-2010, 12:14 AM   #7
wild one
Registered.........
wild one's Avatar
Thumbs up Re: Changing rod link shift to cable shift on column
Very Nice! I used the Lokar kit for mine, had it installed for over two years now. I had to modify the set up as it was for a 67 and up application - after installation my shifter operated bacwards (park was first, reverse was second etc..). After I figured out a solution, man what a difference - precise gear selection every time with no hang ups!
That being said, I sure wish I had thought of or seen a cable set up off of a newer truck, there's nothing like factory parts for ease of maintenance and replacement parts. Great job!
1966 C10 panel-400 small block/TH 350 combo
Nothing is fool proof to a talented fool!
Popcorn:
Pops at exactly 444 degreese
Expands to 44 times it's original size
Has a 4 year shelf life
wild one is offline   Reply With Quote
Old 04-20-2010, 12:48 AM   #8
Captainfab
60-66 Nut
Nice job low79fx
Is that an original auto column in your truck?
Old 04-20-2010, 07:33 AM   #9
low79fx
Originally Posted by Captainfab View Post
Nice job low79fx
Yes it is.
One thing I do have to admit is that the shift arch is not wide enough as I can only get it to drive gear,I will have to redo that column link and increase arch angle to give it more swing to be able to get into 1st & 2nd gear.But for now it works great,and yes for the gears it does hit,it is dead on.What a difference.
