Old 04-16-2010, 01:56 AM   #1
c10seconds
c10seconds's Avatar
Which master cylinder is best for Disc/Disc???
Which master cylinder/proportioning valve are you guys using with your four wheel disc brakes???
c10seconds is offline   Reply With Quote
Old 04-16-2010, 08:10 AM   #2
skeeterbug
skeeterbug's Avatar
Re: Which master cylinder is best for Disc/Disc???
im glad you asked that question, im in need of the same info only booster,prop valve and mastercylinder
'71 LWB c10-"WORK" in progress
385 ci 4 bolt (4.040 bore), scat 6.0" forged h beams,scat forged crank 3.750, speed pro 5cc flat top, clevite bearings, .039 head gaskets,comp xr288hr 110* 288/294adv. 236/242@.50 555/576 lift, pbm hyd roller lifters, chad spiers 215cc imp. heads , comp 1.6 roler rockers, comp magnum push rods, edelbrock victor jr. single plane intake p&p (1206 gasket matched), quickfuel 750R DP , th 350 trans, 5.14 gear, 3000 stall
2012 best 1/8- 7.70 @ 87mph 1.70 60' (lil better)
2013 best 7.39
2014 best-7.38
New for 2013-strange rear coilovers, headman 1-3/4 headers, 5.13 r&p, .060 aluminum bed floor, 15x14 holeshots w/ 31x18.5 hoosier dot pro's, 15x4 holeshots w/ 26x5.5 m/t skinnies and 200+#'s in body weight loss & 6 point cage
skeeterbug is offline   Reply With Quote
Old 04-16-2010, 10:21 AM   #3
Shane
Shane's Avatar
i'm using a '70's model Corvette master cylinder with an aftermarket disc/disc prop valve
Shane is offline   Reply With Quote
Old 04-16-2010, 10:31 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
What brand prop valve, and is it adjustable?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-16-2010, 01:01 PM   #5
cdowns
cdowns's Avatar
i'd look into a late model silverado master and booster and prop valve setup if i ever went to 4wheel disc on an old truck
Old 04-16-2010, 05:55 PM   #6
nlped
nlped's Avatar
I spoke with Jeff @ CPP, and he recommended there part #mcpvs-4 for this specific application. It's the M/C and the disc/disc proportioning valve together.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-17-2010, 12:22 AM   #7
Shane
Shane's Avatar
CPP ... non adjustable.
Old 04-17-2010, 06:35 PM   #8
mickeymouse
Gents, it's not the Master Cyl, but the proportioning valve that makes the difference.
Drum brakes require 8psi of residual pressure to keep the shoes out. The prop valve has a check in it to keep that 8lbs.
Disk brakes don't need as much.
Heck, some folks take a drum prop valve, remove the check valve from the rear circuit and run what they own.
I've done that on a few occasions.
mickeymouse is offline   Reply With Quote
Old 04-17-2010, 07:13 PM   #9
mbgmike
We offer the same setup for less the Corvette MC's run $39.00 plus add the kit below for $70.00
http://estore.websitepros.com/126980...ASS/Detail.bok
Ours are warranteed for life and you have a two year return on it if not used
picture is kind of bad. its a right side mount but we offer them in left side and bottom. aluminum and chrome plated brass
mbgmike is offline   Reply With Quote
Old 04-20-2010, 10:38 AM   #10
nlped
nlped's Avatar
Isn't this for a disc/drum setup?
Carter
Old 04-20-2010, 06:21 PM   #11
mbgmike
Yeah but if ordered we put on the correct one for 4 wheel disc. Same setup same price
Old 04-20-2010, 09:47 PM   #12
weekendracer728
weekendracer728's Avatar
I heard a lot of guys are running a m/c off a chevy monza. It has a 7/8 bore so you dont need to run a booster.
weekendracer728 is offline   Reply With Quote
Old 04-20-2010, 09:49 PM   #13
dnd1978
dnd1978's Avatar
Im facing the same problem. I think im going with a MCPV-1 Master Cylinder from cpp. The all NEW MCPV-1 which combines the master cylinder, double adjustable proportioning valve, removable metering valve and stop light control all in one compact light weight unit, available for Disc/Drum or Disc/Disc applications.
it only cost $199.00
http://www.classicperform.com/NewPro...V-1/MCPV-1.htm
dnd1978 is offline   Reply With Quote
Old 04-25-2010, 10:33 PM   #14
skeeterbug
skeeterbug's Avatar
shane are you running a booster, if so what size and is it a single or dual diaphram?
2013 best 7.39
2014 best-7.38
Old 04-26-2010, 08:56 AM   #15
Shane
Shane's Avatar
I am running a stock truck booster on stock brackets ... 'Vette m/c bolts right up.
