![]() Join Date: Apr 2010
Measuring Tailshaft?
I measured my Turbo 350 tranny tailshaft to see if it was 9" for my 700r4 swap. I measured from where it bolts to tranny to end of yolk. It is 9" between those two points. Did I measure it correctly? If so, the 700r4 is an easy swap with just moving the crossmember, Correct?
Re: Measuring Tailshaft?
no you didnt measure right// its from to the end of the casting ,yoke is additional
the original tailshafts in these trucks were all 6"tailshafts you need to move the crossmember and shorten driveshaft
Here is a picture showing the correct measurements.
Tim |
Thanks you very much. Mine is 6". Guess if I run the 700R4, I will have to have driveshaft shortened. Bummer.
Hey CDowns, If I run the 200-4R, I don't have to modify driveshaft, is that right?
no driveshaft mods required for the 224R just reposition crossmember
![]() Join Date: Sep 2007
is your truck a long or short bed? I m having to cut my d/s 3". (longbed)It was cut previously for a long tailshaft 350.
1967custom |
