Rear Coil Question
Gents-
OK so I am replacing my rear coil springs and have a few questions/issues. 1. Does the retainer cup have a square nut welded to it? 2. Unfortunately I broke the bolt heads off both sides from the bottom....any suggestions on getting them off? I don't have a torch.... Thanks in advance! |
Resistance is Futile
Re: Rear Coil Question
I didnt on my truck. I used new hardware when I replaced my springs. I would think that you could hammer the bolt straight up thru. I know it was fun trying to get my fingers back in there to put it together!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
yes the cup has a nut welded. not sure how your gonna get it out without cutting or torching
BLAZER THIRTY!!
![]() Join Date: May 2007
pound the bolt up thru and cut the nut off of the retainer
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
HOW long until spring??
![]() Join Date: Mar 2009
A little heat works wonders-- even if it is a propane bottle torch. Do not heat the springs , they will lose the temper.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
Check this out.......no nut. Is this the part you're talking about? These are replacement, but my originals were the same as the pic.
On mine ,,tops had no nut,,bottoms had nut welded on.....
Wierd.....another 60-66 mystery I guess.
yup --mine also
No nut on top retainer cups...square weld-nut on bottom retainer cups. I have have several good examples in my lot and have replaced several for myself and others. Weld-nuts on both top & bottom, to eliminate the nuisance of getting your fingers in there to start the nuts.
Well thanks for all the replies gents, I hit them with some penetrating oil and will go back at it again today. I am going to take the tops off and see if the old bolt can be pulled through. If not I guess I will have to go buy an electric cut off or something.
Senior Car Nut
![]() Join Date: Jan 2008
WRO44, I had a similar problem. As you know, the lower bolts go through the trailing arms, and, if they're like mine, the entire length of the bolt is rusted solid to the trailing arm, not just to the welded nut. It is virtually impossible to get penetrating oil down around this length of bolt. You can get heat to the area.
Like you, I was replacing my springs (my old ones were worthless, having been torched by the P.O.). If I remember correctly (I DO suffer from CRS), I got the spring tops loose then cut the springs down low to get them out of the way AFTER PROPERLY SUPPORTING BOTH THE FRAME AND THE REAR AXEL AND DELOADING THE SPRINGS. Then you can use a chisel as a wedge between the spring/cup and the trailing arm. If you can loosen it any at all you can start getting oil to it. Driving the bolt up from the bottom is difficult because it is tough to get a good swing with the tool of choice, the BFH.
Larry Last edited by fleetsidelarry; 04-17-2010 at 09:31 AM. |
Alright fellas- I broke down and just bought an angle grinder and cut the spring off. The top retainer cup came off easily after I cut the bolt. HOWEVER.... the bottom bolt that ran all the way through the trailing arm is still being a PITA! I think I am just going to end up drilling the darn thing out. I will keep ya'll posted on the progress.
Senior Car Nut
Did you get the lower cups off? If not, now that the springs are out of the way, soak the cup nuts good and use a crescent wrench to see if you can get the cups off. Even if they snap off you can then just drive the rest of the bolt DOWN through the trailing arms which will be way easier than trying to drive them UP as you can support the arms and get a better swing with the hammer. I my opinion, drilling will be tough. I think once you can get a good whack at that bolt it will start, also, with the cups out of the way you can soak the bolt better.
Larry Last edited by fleetsidelarry; 04-17-2010 at 09:18 PM. |
#15 |
SUCCESS! Finally got both the bottom bolts all the way out. The driver side I was a little smarter and just ground the nut off leaving the bolt to swing a BFH at...she popped right out. The passenger side was a little tougher....soked with a bunch of penetraiting oil and heated it a few times, then finally drilled a hole in the top, got a punch in there and then went at it with the famed BFH! All in all it was a successful weekend, now just gotta wait till the new cups and bolts come in and install! Thanks again for all the help gents!
#16 |
Senior Car Nut
Allright! Just a suggestion, when I reassembled mine, I coated the entire length of the bolts with grease to, hopefully, make it easier to take apart next time.
Larry |
#17 |
#18 |
An air hammer with a pointed tip is a geat way to drive the bottom bolts out of the trailing arm. Also, with your impact and a 3/4 socket, turn the bolt clockwise and counter-clockwise several times. This, along with penetrating oil & heat, will allow the rust to break up and the bolt to be easily removed.
I have also tapped on the die-pressed hump at the center chord of the trailing arm, on both sides, to help break up the rust in the bolt cavity. Jacking the frame up until the rear wheels are barely contacting the surface and not able to rotate, will relieve the energy of the coils, avoiding any runaway springs. Remove the lower caps and bolts first. The coil can then be moved to the side of the top flange of the trailing arm, to allow a deep-well socket and an long extension to be inserted through the bottom of the coil spring and allow loosening of the top bolt. The coil will fall out in your hand, once the bolt begins to loosen and fall from the weld nut in the frame rail. When installing new coils, install the top retaining cup and bolt, finger tight, followed by the lower cup and thru-bolt. Once both top and bottom bolts are started properly and finger tight, relieve the jack, to allow the frame to rest on the coils on the trailing arms. This will secure them, to allow tightening and torquing the bolts. Last edited by LILRED66; 04-29-2010 at 12:52 AM. |
#19 | |
fan of "Butters" Stotch
Are the top cups and bottom ones the same? I'm asking since my bottom ones are gone. One of the previous owners never put them back in after heating and cutting the springs (they are not pretty looking)
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() Last edited by tapeworm; 04-30-2010 at 08:24 PM. |
#20 |
tapeworm:
The top coil retaining cups do not have a weld nut on them. The weld nut is on the top side of the lower frame flange and the bolt goes through the retainer cup, into the weld nut from inside the coil. Getting the bolt in from the top and tightening it, if there was a weld nut in the cup, would be very difficult. The bottom coil retaining cups have a weld nut. The bolt goes through the pocket in the trailing arm and into the bottom coil retainer cup with the weld nut on it. Inserting and tightening the bolt from the underside of the trailing arm, into the cup, is easier than from the top, inside the coil. Last edited by LILRED66; 04-30-2010 at 08:51 PM. |
#21 | |
![]() My bottom ones are not even there (no bolts either)
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again ![]() |
#22 |
I have purchased the complete kit, including two top coil spring retainer cups, two bottom coil spring retainer cups and the mounting hardware for around $20.00, plus tax. Replacing the entire set, is a good thing to do, especially, if they are missing altogether.
#23 |
I was just thinking the same thing-
I think I saw the kit at Classic Parts Thanks again!
#24 |
I got mine for like $20 shipped through CPP on thier Ebay store.
