Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-06-2010, 08:33 PM   #1
blazer2007
ford 9 in info needed
Trying to find a ford 9 in. for my truck,454 475 hp.so I can change gears when needed.I found one that is possibly from a 73 and later car[t-bird or lincoln not sure] but from what I,m can find find is these have a tapered axle or tube,not good for shortening.I don,t want to shortenin it,is a good width for me.So my ? is, is this a rearend I should take or is this style rear a weak unit that can,t be helped without lottsa $
blazer2007 is offline   Reply With Quote
Old 05-06-2010, 08:44 PM   #2
blazer2007
Re: ford 9 in info needed
sorry, but rearend is not where I am,is from a friend of a friend who saves ford 9 in. so I have to go buy hearsay
Old 05-06-2010, 08:55 PM   #3
midevil1
ShortBus KingPin
midevil1's Avatar
One thing that they are not is weak. If it is out of a small block car, then it has 28 spline axles. Which are fine with street tires. BBF cars had 31 splines and factory posi's. Lincolns and T-birds are already quite short around 50" if I remember correctly. I put one in a foxbody I had without cutting a thing.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 05-06-2010, 10:12 PM   #4
djracer
djracer's Avatar
If its the right width I'd say go for it.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 05-07-2010, 12:35 AM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Do some research and be CERTAIN. There are ford 8.8" rears that 'appear' to be the same as a 9" but not. How to tell and what exactly to look for I can't help. just to offer that word of caution.
Ya know if you look at the cost of a new housing, fitted with the housing ends for big axles, ordering new axles, a locker, gears, and everything. You might be better off doing this from scratch. 'Stock' 9" parts are pretty strong, but not anything indestructible for sure. Even aftermarket Pro center-sections, 40 spline axles, and Richmond gears can go away with enough abuse. I just threw away a Richmond 5.43 ring and pinion that lost some teeth with a 12 second truck launching off a transbrake.
just saying....
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-07-2010, 01:23 AM   #6
Nick's81
Nick's81's Avatar
how about 1 from a 57 ford trk can pick it up for 100 oppinions please
Nick's81 is offline   Reply With Quote
Old 05-07-2010, 09:21 AM   #7
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
I've decided to give you one more chance. Here is the best 9 inch info page I have ever seen. Lots of info and might help in your search.
http://www.kevinstang.com/Ninecase.htm
prostreetC-10 is offline   Reply With Quote
Old 05-07-2010, 10:39 AM   #8
blazer2007
It is a 9 inch and is from a running car all in good shape [we,ll see]for 200.00,At least I can put on the bench and take my time
Old 05-07-2010, 06:44 PM   #9
blazer2007
I don,t need one last chance from you,but thanks for the info
Old 05-07-2010, 09:42 PM   #10
midevil1
ShortBus KingPin
midevil1's Avatar
Find out what motor was in that car originally. It will tell you alot about that rearend before you break it open. You have 3 different bearing sizes on the carriers. 2.80 which is low performance apps. 3.06 bearing which was in most trucks, 3.250 bearing which is the bigboy and is for the high performance apps. You can change any 9 inch housing to hold whatever carrier you want, but it is nice to have the good stuff already....
Old 05-07-2010, 11:51 PM   #11
prostreetC-10
My Carbon Footprint
It was a joke and I said more not last.....talk about not reading the posts. lol
Old 05-08-2010, 09:08 AM   #12
midevil1
ShortBus KingPin
midevil1's Avatar
Well you would have one of the first off the assembly line, thats for sure.
Alot has changed in 60 years, but If the posi is in good shape it would probably handle 450hp all day long.
