Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Closed Thread
Old 06-23-2007, 08:56 AM   #1
LILRED66
LILRED66's Avatar
'64-'66 Chevy Truck power steering conversion
After doing several power steering conversions, I have fabricated a pair of inner and outer backing plates for the frame rails and mounting for the GM Saginaw power steering gear box. I had the backing plates lazer cut from 1/4" 304 stainless steel. The mounting hardware is Grade 8 bolts, nuts and washers.
The complete kit, including front & back backing plates, hardware and spacers, is $85.00, plus $6.00 packaging & shipping. This kit allows mounting of a '68-'86 GM Saginaw power steering gear box, to convert a '64-'66 Chevy truck from manual steering to power steering.
This kit does not include the gear box, pump, hoses, belts or rag joint.
Let me know if you are interested in one of these quality kits or need additional information.
Tony Smith
4-5-6 Chevy Trucks
913-207-7789
dynamiccontracting@sbcglobal.net
LILRED66 is offline
Old 06-25-2007, 08:20 PM   #2
teejay65
Re: '64-'66 Chevy Truck power steering conversion
Tony,
how do I get payment to you...paypal, visa, check or money order? I live in Madison, AL 35756
TeeJay
teejay65 is offline
Old 01-27-2008, 02:44 AM   #3
LILRED66
LILRED66's Avatar
bump
LILRED66 is offline
Old 01-27-2008, 04:47 AM   #4
62 short step
62 short step's Avatar
I bought one of these kits, but for my 61 4x4 and installed it. Worked excellent, thanks again Tony!!
62 short step is offline
Old 07-30-2008, 10:40 AM   #5
LILRED66
LILRED66's Avatar
I just got a few more sets in...just in time for that power steering conversion! Let me know if I can help you with this item or other 4-5-6 Chevy truck parts in the future.
LILRED66 is offline
Old 08-09-2008, 12:30 AM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
Tony,
I am interested in this conversion. After mounting the steering box, what parts do I use for the drag link, tie rod ends ETC? I have a 64 Chevy stepside.
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline
Old 08-11-2008, 10:49 PM   #7
LILRED66
LILRED66's Avatar
Originally Posted by Arad68 View Post
Tony,
Don:
Thanks for the inquiry. Your factory suspension parts will work. You will need a GM Pitman arm that fits your power steering box. You can use a '68-'86 GM Saginaw power steering box and Pitman arm. You will also need a new rag joint that fits the splined shaft on you GM Saginaw power steering box. I hope this information is helpful and let me know if I can help you with one of these conversion kits or other 4-5-6 Chevy trucks parts in the future.
LILRED66 is offline
Old 08-14-2008, 08:57 AM   #8
67c-10Texas
do you know if tis will work on my 67 -
67c-10Texas is offline
Old 08-14-2008, 09:55 AM   #9
LILRED66
LILRED66's Avatar
This kit is specific to the '64-'66 Chevy trucks, so I couldn't tell you if it will work on your '67. I believe power steering was available in '67, so you may not need the conversion kit, in order to bolt up a power steering gear box. You may try posting in the '67-'72 forum for some better input from the experts there.
LILRED66 is offline
Old 04-13-2009, 07:50 PM   #10
LILRED66
LILRED66's Avatar
Just in time for the spring cruise season.
LILRED66 is offline
Old 04-13-2009, 10:31 PM   #11
kwernli
kwernli's Avatar
Can you help with parts for a power steering conversion on a 65 4x4?
kwernli is offline
Old 04-14-2009, 06:21 PM   #12
LILRED66
LILRED66's Avatar
When converting a 4-5-6 Chevy 4x4 the drag-link must be cut and welded 90 degrees out of true, as well as, the steering shaft must be shortened slightly. I have done the conversion on several factory 4x4 trucks.
I see you are in Sedalia, MO. I can do the conversion, if you want to bring the truck to my shop in Kansas City, KS. It is not that much different to do the conversion on a 4x4 than it is on a 2wd truck.
LILRED66 is offline
Old 04-14-2009, 09:15 PM   #13
kwernli
kwernli's Avatar
Thanks for the advice Tony. I currently have the truck stripped to the bare frame so I can’t get it to you, but I would like to visit your shop sometime. I’m going to be needing a lot of parts.
kwernli is offline
Old 04-15-2009, 08:59 AM   #14
LILRED66
LILRED66's Avatar
Thanks for the prompt reply and it would be tough to bring it to my shop. I can show you a 4x4 conversion when you come to my shop. Take care and let me know if I can help you with anything. Good luck with your project...it looks like you have a great start.
LILRED66 is offline
Old 05-26-2010, 09:58 PM   #15
luckylindy6
Well I'm gettin somewhere now, been workin on this for a year now, absolutely love this color
luckylindy6 is offline
Old 05-27-2010, 02:11 AM   #16
LILRED66
LILRED66's Avatar
Nice progress. My brother lives in Central Point, OR, so let me know if you need any parts...we have 8-10 trucks at his shop, that we use for parts and projects.
LILRED66 is offline
Old 05-27-2010, 01:22 PM   #17
luckylindy6
awsome I'll do that, let me know if you get out this way I'd love to check out your ride!!
Old 05-27-2010, 09:26 PM   #18
luckylindy6
Hey can you tell me what you use for power brakes as far as a power booster/master cylinder setup, right now I used a 79 chevy pu set up, all I had to do was lenghten the pushrod about 2" to get it to work but only two of the mounting bolts line up and that year setup had 6 bolts, two up real high that will never lineup to anything, two that line up perfect and two that will need to be drilled, thot I saw a bracket setup for mounting that made some year booster line up right? not sure if it was yours or not
Old 06-05-2010, 08:53 AM   #19
LILRED66
LILRED66's Avatar
Thanks for the inquiry. I think you need one of captfab's booster mounting brackets.
LILRED66 is offline
Old 06-24-2010, 04:35 PM   #20
LILRED66
LILRED66's Avatar
This kit is specific to the '63-'66 Chevy 1/2 ton K10 4x4 trucks. All four gear box holes fall in the center web of the frame rail. We just got a new shipment in from the lazer cutter, so we have these kits in stock.
LILRED66 is offline
Closed Thread
