Old 05-14-2010, 02:32 PM   #1
wholio
wholio's Avatar
67-72 chevy c10 under a blazer 69
how hard would it be to swap out my frame which is a 1969 k5 blazer for a 2wd 67-72 frame?
wholio is offline   Reply With Quote
Old 05-14-2010, 06:06 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: 67-72 chevy c10 under a blazer 69
Are you talking a PU frame? They are different wheel bases so you'd have to shorten the frame. The suspension from a 2wd PU will fit on the blazer with minor modifications and would be far easier than a frame swap. If you're planning on baggin it, you can go lower with a converted 4wd frame. Check out this article from sport truck magazine.
http://www.sporttruck.com/techarticl...ion/index.html
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-14-2010, 06:10 PM   #3
71swb4x4
71swb4x4's Avatar
As bouncy said it's easier to convert a 4wd frame. The pickup frame is longer, and the body mounts are all wrong.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-15-2010, 02:03 AM   #4
chevyblazer
chevyblazer's Avatar
Yep its better to convertthen change the chasis the other chasis has diferent the curve where the box goes
chevyblazer is offline   Reply With Quote
