door handle ? help
I have a 86 gmc that i need to replace the out side door handle... im tryin to get it apart in side the door and there is some kinda clip i cant seem to get apart any one know how or what to to get it apart?
04 Chevy Duramax LLY crewcab 4X4 Built ATS Allison Upgrades ![]() 75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift. |
Re: door handle ? help
Its easier to get at if you take the door latch off (3 phillips screws and may have to hit screwdriver with a hammer while turning) first then I just use a flathead screwdriver to push the clip down some.
To re-install you put the clip in place and the rod will slide in but not out if that makes sense. |
#3 | |
'86 is probably the plastic one? Isn't it? If so, it just rotates toward the inside of the door. It snaps around the rod, so it takes some prying.
Unless it's the metal clip? I don't remember? It has been a long time since I had one apart and I have worked on hundreds of cars/trucks, so it's hard to keep them straight. If it's the metal one: It just slides upward, but you have to lift the "tab" out of the hole first. It has a "barb" like a fishhook, just slide something thin under it and the whole clip will push like it is going to slide off of the end. It will probably fall down into the door when you pull the rod out, be prepared to dig it out. To put it back together, you slide the clip back onto the handle before putting it back in the door. Then the rod just pushes in and "catches"
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
My 86 is metal I was assuming his was also.
![]() Last edited by HOGDADDY; 05-23-2010 at 01:28 AM. |
