Old 05-19-2010, 04:52 PM   #1
Dapper Dan
Dapper Dan's Avatar
700r4 seal question
My leak is getting worse and I have read as much as I can find on replacing the front seal. I feel pretty comfortable with removing the tranny but I haven't much info on actually replacing the seal. Is it as easy as prying old seal out and putting new one in? Do you have to remove the pump or not?
Also I just replaced the filter and pan gasket is there any thing else I should replace while it is out? Thanks for the help
Dapper Dan is offline   Reply With Quote
Old 05-19-2010, 04:54 PM   #2
michael bustamante
michael bustamante's Avatar
Re: 700r4 seal question
the fluid are you talking about the front pump seal?
1967custom
michael bustamante is offline   Reply With Quote
Old 05-19-2010, 05:17 PM   #3
Dapper Dan
Dapper Dan's Avatar
I knew I was missing something! and yes the front pump seal
Old 05-19-2010, 05:57 PM   #4
clinebarger
Yes the seal can be installed without removing the pump.
Be carefull when prying the seal out, you dont want to damage the pump bushing. Inspect the bushing for wear & damage, If it is damaged it needs a new bushing & will require removing the pump. If the bushing is good proceed with installing the seal using red loctite on the outside of the seal (700R4s are known for blowing pump seals out, using loctite is cheap insurance)
All other seals can be done with the transmission in the truck.
clinebarger is offline   Reply With Quote
Old 05-19-2010, 06:01 PM   #5
Jonboy
Slots go on anything!
It really is that easy. Once the trans is out, pull the converter out. Remove the old seal, and tap the new one in place. When you put the converter back in place, make sure it is fully seated, or you may have trouble getting the transmission back in place. You will notice two tangs on the converter snout, it is imperitive that they are realigned back into the pump. There will be two sets of splines that you will feel line up, then the tangs in the pump. Just spin the converter with a little pressure from the front, and you will feel them engage.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-19-2010, 06:09 PM   #6
Dapper Dan
Dapper Dan's Avatar
Thanks for the quick answers. I am trying to replace what I can myself ,the shop said to pull it and reseal it would run $500. It shift and drives perfect so if I can get another year or two before a rebuild with a $6 seal I'd be a happy man. If this doesn't get it it's off to the shop.
Thanks again
Old 05-19-2010, 10:29 PM   #7
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Some of the 700s have a front seal retainer.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-25-2010, 04:13 PM   #8
Dapper Dan
Dapper Dan's Avatar
Just wanted to say thanks again! I just finished cleaning up after about 5 hours laying on concrete. But after 10 miles no sign of the leak so if it holds up it was worth it, fingers crossed. I need a nap...
Old 05-25-2010, 08:09 PM   #9
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Most 700R4 don't leak at the seal. It's the brass bushing that leaks. If you find that the bushing is not leaking, replace it anyway. It will be good maitenance.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
