Old 05-29-2010, 11:28 PM   #1
Fraser Beatty
Fraser Beatty's Avatar
Which Year Boxes Will Fit?
Hey all...I'm looking at replacing the box on my 80 GMC C25. Just wondering what years of boxes will crossover? Will any 73-87 box be useable and look correct, or will only certain years work? Reason I ask is I can pick up a good useable mid-80s box with only very light surface rust for $200, less than cost of repairing the one on the truck now.
1961 GMC 930- SOLD
1979 GMC C35 Single Wheel Camper Special- SOLD
1980 GMC C25 Camper Special- SOLD
1983 Chevrolet C10- SOLD
1983 Chevrolet Camaro- SOLD
1985 GMC C1500 (Dad's truck)
1985 GMC C3500 Crew Cab Dually- TRADED FOR 61 GMC
1997 Dodge Ram 1500 V6 Shortbox- Daily Driver
Fraser Beatty is offline   Reply With Quote
Old 05-30-2010, 12:02 AM   #2
bitchin85
bitchin85's Avatar
Re: Which Year Boxes Will Fit?
pretty sure the only diference is the earlier ones had a round gas filler hole and the later ones had a square one.. the tailgates are a little diferent but you can whitch your old one on if you want with your old brackets
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 05-30-2010, 09:18 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
They will both be the gas filler door type beds so the only difference is the tail gate in your case.
They started switching over from the exposed gas cap beds in 78. Not sure if it was an option or a mid year change but some 78's (like my K20 built in Nov 1977) have the exposed gas cap and my brothers old 78 had the filler door type bed.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 05-30-2010, 05:19 PM   #4
tucsonjwt
If you are talking fleetside beds, the beds themselves for 1/2 and 3/4 ton trucks will interchange, but the bolt patterns don't always match. Check the bolt location pattern and length of bolts, as well as the gas tank setup before you buy one for your truck. If you need to replace the filler neck and fill hose(s) with new ones, your $200 box might cost $400 - unless you find good junk parts cheap. I have noticed that used parts for these old trucks are not selling as cheap as they should for the number that are out there.
tucsonjwt is offline   Reply With Quote
Old 05-30-2010, 08:38 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
FYI
A neighbour of mine fixed a white pickup that it looks like he put a 88 size box on a earlier 80's year cab,the cab looked wider then the box.I can see about a pic it's close to my house
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
