327 V8 small block flywheel.
Hi All,
Now that I know the bell housing will work. Does anyone have a link to a site selling flywheels for a 327 small block? I'm pulling the 230 L6 out and dropping a 327 in its place. Attaching it to the original 3 on the tree tranny. I'm a rookie and not sure what flywheel I need. I'm sure the one on the 6 will not fit on the 327. Also can anyone tell me if they upgraded their radiator to a larger size upon upgrading the motor and what they used? Thanks! |
Re: 327 V8 small block flywheel.
![]() Not sure on the flywheel, someone else can answer but you will need a minimum of a three row radiator with the upper hose on the left and lower hose on the right. The pic is from summit, good prices as any if your looking new...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Depending on which radiator you currently have you may be able to have it re-cored using the 3 row core mentioned by Rich in this thread.
I did this to my factory V-8 radiator and it made a considerable difference. |
Your 230 flywheel will bolt up to the 327 crank and look like it grew there. I have kept the 6 cyl radiator on V-8 swaps with no problems, but YMMV.
Ray |
I will get some help as soon as I can and pull the 6 and take it apart and check the flywheel.. that would be great if it fits!! I had heard there was a diff between 6 and 8 wheels. As for the radiator. It is possibly a 3 core but it is only 1" thick where I hear most people run a 2" wide core for the v8's. I suppose I'll hook it up and flush it and run the truck and watch temps for now to see if it heats to much. I just want to be careful because it's a fresh rebuild on the 327.. I don't want to over heat it. Thanks for the info.. much appreciated :-)
Enjoy your truck
I ran my 230 ci flywheel for years on the 283 I put in my '63 without any issues.
As for the rad, the bigger the better. But as an FYI, I just put an Edelbrock water pump on my 327 and it made a noticeable difference in the operating temperature. As much as cooling is about capacity, it is just as much about flow (as I just found out). Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
I think you`ll find that the 6-rad will work for fire up,, but won`t do the job at highway speeds as I`m assumming you`ll have 373 gears or 411 gears, winding that motor that tight at highway speeds it won`t cool it down.
