Old 02-19-2003, 12:54 AM   #1
J-Spec C10
Whats this wire for?....
J-Spec C10's Avatar
Crazy Wind noise...
When I'm driving on the highway, I get wind noise from both doors/windows and somewhere behind the seats I feel cold air too I can't hear the radio over the wind. Does anyone else get this problem too?
The vent windows are closed, but I still see a gap at the top leading edge of the glass, can I fix this?
All new seals are very expensive, any quick fixes? Other than silicone
Kyle
CANADIAN CONNECTION
'82 C10 Resto-Custom--> * 2 1/4" manifold back dual exhaust with Hooker Aerochambers & High Flow Cats *Taylor Ignition Wires *Centerline 15" Telstars with 32"x10" mudders
J-Spec C10 is offline   Reply With Quote
Old 02-19-2003, 02:12 AM   #2
Trick76
Living la vida broka
Trick76's Avatar
Duct tape
1976 C10 Longbed lowered 5/7, hot 355/TH350. ~ SOLD
1974 C10 Shortbed Stepside 350/Saginaw ~ SOLD
1984 C10 Longbed 6.2l diesel 700r4. ~SOLD
1985 GMC C20 350 700r4, ~under the knife
Trick76 is offline   Reply With Quote
Old 02-19-2003, 02:16 AM   #3
Prerunner1982
Prerunner1982's Avatar
i put large pieces of paper under the latch on the vent windows...
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 02-19-2003, 02:19 AM   #4
ocbaud
Garage Queen Material
my velvet? seal stuff around my windows is halfway gone and the wind noise in my cab is awful, add to that the rear sliding window that vibrates from my exhaust, and the glove box that vibrates from the exhaust, and its hard for me to hear too
ocbaud is offline   Reply With Quote
Old 02-19-2003, 02:21 AM   #5
J-Spec C10
J-Spec C10's Avatar
duct tape is a good idea, afterall they use it in NASCAR right?
However i think it might detract from the overall look I was going for....
Kyle
CANADIAN CONNECTION
Old 02-19-2003, 02:46 AM   #6
crossy
Oh,you can't buy that new
crossy's Avatar
I hate this but it's what you asked for . go to hardware store and buy cheap stick on foam weatherstrip , about 1/2" wide by 1/4" thick, and add it to all the door perimeter weatherstrip sealing surfaces .
on the vent windows . work some oil into the pivots so that they move freely. close them as tight as they will go. with the 'new' DOOR weatherstrip in place see what kind of noise you get now . pull in on the vents while driving , does it get quieter?? if so try shimming the handle/latches to close them even tighter . I sealed mine with clear silicone. there is another trick left but involved . see how that works , DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 02-19-2003, 09:25 AM   #7
BigRed
This is a very common problem with our trucks. Weatherstripping is probably gone on any trucks older than '85. You can get full replacement kits from JC Whitney and other places. They are not cheap, but are definitely worth it. Before I put my cab back together, I'm definitely replacing all weatherstripping inside and out.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 02-19-2003, 10:26 AM   #8
Low87
been here longer than Liz
Low87's Avatar
Yup, you just have an old truck. New weatherstripping with tighten the cab back up and get the wind out.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 02-19-2003, 10:35 AM   #9
Razorback_Fan
Razorback_Fan's Avatar
So where is a good place to get the replacement weatherstripping?
Razorback_Fan is offline   Reply With Quote
Old 02-19-2003, 11:11 AM   #10
solidaxel
solidaxel's Avatar
Turn up the Radio!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-19-2003, 01:22 PM   #11
BigRed
All the major chevy truck suppliers have it. First, you can try JC Whitney. I've actually heard that their stuff is pretty good.
I have some links on my site also that you check. http://www.shelbournes.net/trucksite/links.htm
Scott Shelbourne
Old 02-19-2003, 04:04 PM   #12
J-Spec C10
J-Spec C10's Avatar
thanks for the help, I'll let you all know how it works out.
Kyle
CANADIAN CONNECTION
Old 02-19-2003, 09:24 PM   #13
bigd65
bigd65's Avatar
if you are like me, i dont use my vent windows (non smoker) i sealed mine with some BLACK SILICONE. cant see it and is a cheap easy fix. (UNTILL SOMEONE COMES UP WITH AN IDEA FOR A ONE PIECE WINDOW TO ELIMINATE THE VENT WINDOW)
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 02-20-2003, 12:38 AM   #14
J-Spec C10
J-Spec C10's Avatar
One piece windows would rock! But I cant see someone tooling up for a run, when the trucks are not in production anymore. From a business standpoint its not a good idea. From our standpoint, it would be great.
Kyle
CANADIAN CONNECTION
Old 02-20-2003, 03:31 AM   #15
bill_ont_canada
Nobody is perfect...
bill_ont_canada's Avatar
Hey Kyle.
What year did GM quit putting vent windows in our trucks ???
Do the '90 Suburbans have one piece windows ??? If they do I think the doors are the same, and... if this is right, we could just get the guts from the wreckers and install them.
Yes, No, Maybe... ????????????????
Have a fabulous day.
Bill... (ö¿ö)
" Loud Pipes Save Lives "
bill_ont_canada is offline   Reply With Quote
Old 02-20-2003, 02:54 PM   #16
J-Spec C10
J-Spec C10's Avatar
Sorry to ruin the hopes Bill, but I think you misunderstood me. What I was trying to say is that since out trucks aren't in producton anymore, nobody would find it economically feasable to make one piece windows for them.
Kyle
CANADIAN CONNECTION
Old 02-20-2003, 06:39 PM   #17
crossy
crossy's Avatar
j-spec , they are not making MANY MANY cars & trucks but it IS profitable for the companies that makes repro parts for them and since there are SO MANY of our year trucks that take the same windows (15 years ) it would definately be profitable. The early Ford f-1 & f-100 people have made a few $$ selling parts for out of production trucks not to mention 67-72 chevy trucks , Mustangs camaros , chevelle vette , etc. and they keep making more . they just have not caught on yet as to how many people are really looking for them. DAVE
98 Vortec project.
94,3500,6.5L 4L80
