Old 11-25-2023, 02:20 AM   #1
General23cmp
Rocker and cab corner factory fitment
I have been told (and seen) that factory rockers didn’t quite align with the cab corners. The rocker’s curve appears to be inset about 1/8” compared to the cab corner curve on factory units. Obviously when people restore these trucks, they frequently make that alignment better when they replace the rocker/corner.
Questions:
Obviously if you align things up perfectly with the door installed, you can get the corner, rocker and door to all meet at the corner very well. If you are going for a more “factory look” with the inset rocker, that alignment with the door wouldn’t be possible. So am I correct that the door on a factory cab would align with the B pillar (the cab corner extending from that) and thus, the door would overhang the rocker about 1/8” there? Does the door maintain the 1/8” overhang of the rocker to the front fender, or does it eventually align? Anyone have pictures?
General23cmp is offline   Reply With Quote
Old 11-25-2023, 05:17 PM   #2
Casper42
Casper42's Avatar
Re: Rocker and cab corner factory fitment
I'm not certain what you're inferring, and probably others here to as no one else has responded. If you say you've seen pictures, maybe post those so we know exactly what you're referencing. cheers
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 11-25-2023, 05:56 PM   #3
General23cmp
Thanks. Never said I had pictures. I asked for pictures of factory bodies at that location to see what factory is supposed to look like. I’m trying to say that the rocker curve and cab corner curve aren’t perfectly in line with each other from the factory.
Old 11-27-2023, 04:43 PM   #4
pjmoreland
pjmoreland's Avatar
Here are some photos of a factory rocker panel and cab corner.
pjmoreland is online now   Reply With Quote
Old 11-27-2023, 05:18 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
From what I see, most people do not fill in the gap at the rocker/corner with seam sealer after repairs have been done and that makes it look worse than it should.
I do have a 72 cab with factory rockers if you would like to see more. It was not flush either.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-27-2023, 09:56 PM   #6
General23cmp
Smitty
I would like to see yours too if you don’t mind. The other poster’s look much better than most factory ones I recall seeing (good for him).
Old 11-27-2023, 05:45 PM   #7
drummingrocks
I'm interested in this as well. I have a '68 stepside that's had both rockers and cab corners replaced. Does anyone have pictures of the rocker at the front of the door area?
drummingrocks is offline   Reply With Quote
Old 11-27-2023, 05:49 PM   #8
pjmoreland
pjmoreland's Avatar
Hard to get a good photo with the door installed.
Old 11-27-2023, 05:54 PM   #9
pjmoreland
pjmoreland's Avatar
Not the best photo, but here's one I took when I had the door and fender off.
Old 11-27-2023, 09:53 PM   #10
General23cmp
Thanks for all the pictures. Those rockers have never been off? That rear cab corner and rocker alignment looks much better than most I’ve seen (the reason for the post). That’s great info.
Old 11-27-2023, 10:08 PM   #11
pjmoreland
pjmoreland's Avatar
I do not believe the rockers on my truck have ever been removed. They still have the original paint on them and the factory spot welds.
Old 11-28-2023, 08:24 AM   #12
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Rocker and cab corner factory fitment
This is consistent with the times in which they were assembled. Some were built great, and others not so much. My '72 Flint assembled Super has the original rockers, and they fit great. Door fit is not as good, with huge gaps in the front, and tight in the back.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
2017 Sierra 1500 SLT 4WD, Black, 46k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 67k miles, 3.6, 8L45, 3.23 LS, 18" wheels
1970cstblazer is online now   Reply With Quote
Old 11-28-2023, 12:27 PM   #13
chewychevy67
Yes mine had large gaps in the back of the door to cab on driver side. My metal guy had to remove and rework the top chanel to get the original door to fit better. But I believe the rockers and cab corner was lined up ok on the driver side but the rockers got replaced anyway.. Passenger side he barely had to adjust.
chewychevy67 is offline   Reply With Quote
Old 11-28-2023, 04:23 PM   #14
71meangreenc10
As requested.
As you can see the back is not even close to square with the rocker and the cab corner. Hard to get the money shot, so I added in a straight edge to help out.
Smitty
71 C30 Wrecker
Old 11-28-2023, 09:07 PM   #15
General23cmp
As requested.
Smitty
Thank you so much. That is exactly what I had seen before and was told… about an inset of 1/8” where the rocker meets the cab. A well-respected vendor on here told me that factory looked that way too (that is the way my repops were fitting). He said many people work them to make them align perfectly, but 1/8” was common.
Old 11-28-2023, 11:10 PM   #16
71meangreenc10
Not a problem.
Smitty
71 C30 Wrecker
Old 11-29-2023, 08:51 AM   #17
1970cstblazer
The industry fit and finish standards in 1972 are far different than what is expected today-especially trucks. I would bet few buyers back then even cared about globs of seam sealer, runs in the paint, or inconsistent panel gaps and panel fitment. It was just how it was.
A lot of restorations make these things much nicer than they were right off the showroom.
Old 11-28-2023, 05:59 PM   #18
Lee H
Lee H's Avatar
Mine are the same as pjmoreland, rocker, cab corner, and door all in the same plane and flush. Factory, nothing replace or repaired.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
