Old 07-27-2010, 02:17 PM   #1
2500HD
2500HD's Avatar
slight stumble with factory 402
I am looking for help with a slight stumble from 5 to 9 mph and then again from 25 to 31 mph. It is very slight with light throttle and more prevelent with medium throttle. I first thought it was a bad carrier bearing but have ruled that out after inspection and new exhaust was installed.
To cure I installed a pertonix and removed the points. At the same time I installed new cap, rotor, coil, plugs and plug wires. I did not think my vacuum advance was working so I installed a new one after the first test drive and it did not solve the issue. Plugs are gapped at .035 and there is 12 volts to the coild and the pertonix. Timing is set to 9 or 10 degrees. It starts quick and idles smooth.
Any ideas would be appreciated.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
