Old 07-30-2010, 04:51 PM   #1
Blackjeep99
i have leaf springs and need info on axle flip
Iam gona do an axle flip and c-notch on my 69 GMC swb. Has any of you done this ? It is the most affordable way I have come up with. I have done a few flips on jeeps but never a truck or to lower a vehicle before was wanting to know how much it will lower it and if theirs any other small details. Iam lookin for at least a 4 in drop more if possible. Thanks a million !
Blackjeep99 is offline   Reply With Quote
Old 07-30-2010, 06:37 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: i have leaf springs and need info on axle flip
You could always weld on a set of new leaf spring saddles under the rear axle tube.
Like these from POL:
http://www.performanceonline.com/196...-PAIR-RAS6787/
I think your drop will be more like a 6" drop, and may require you to notch the frame.
POL also sells mono and multi leaf springs to lower your truck.
http://www.performanceonline.com/196...AF-SPRING-SET/
Keith
Convert to disc brakes.
Old 08-01-2010, 03:02 AM   #3
raycow
You can get a pretty good idea of the drop you will get from a flip (assuming you keep the same springs). Add the thickness of the spring + the diameter of the axle tube + 2X the height of the spring perch off the tube. The total of all this is the amount of drop you can expect.
Ray
raycow is offline   Reply With Quote
