Old 08-11-2010, 12:26 PM   #1
tolly4503
Another Vortec Question
I found some rebuilt Vortec heads on Craiglist fr $300, casting number 906, I've read on here that, they may/may not flow as good as others, but they have to flow better then the heads on my '69. Does this seem like a fair price, and how much better would say the Summit Vortec heads be. I'll probaly be goin this weekend to look at them. Thanks
tolly4503 is offline   Reply With Quote
Old 08-11-2010, 03:03 PM   #2
tonypaul
tonypaul's Avatar
Re: Another Vortec Question
In my dealings with Vortec heads I found that they are a good addition if they are coupled with a good combo of cam and intake and exhaust. Without knowing more about your engine, I doubt anyone will really be able to tell you if they will do you any good are not. On a old worn out stock sbc, I wouldnt install them. I would personally save the money for a good aftermarket head and cam package, or find a good set of double hump heads and have them ported and polished. Or just look around on craiglist for a good rebuildable 350 (see them all the time for $500.00 and less) and rebuild it over time. Just my 2 cents worth...
tonypaul is offline   Reply With Quote
Old 08-11-2010, 03:42 PM   #3
tolly4503
The bottom end is still good(66000 miles) and I plan on getting a different cam and the vortc intake. Right now I'm just getting the peices together. I was just wondering if if seems like a good deal or not, thanks
Old 08-12-2010, 09:05 AM   #4
68_chop_top
68_chop_top's Avatar
Vortec heads are a good deal IF you haven't bought your intake manifold yet. Back in 2002 when I bought my Vortec heads I paid $500 for ready to bolt on. They claim as good almost as some aftermarket aluminum heads. I had not yet bought my intake so I could go either way. IF you already have the intake then I would match the heads to the intake you have.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 08-13-2010, 11:52 PM   #5
pitbull784
the 906 castings are the best vortec castings to get, it would be a great improvement over stock 69 heads. I ran a set on a 350 with a mild roller cam and rpm intake im my shortbed and was running consistent 13.10 at 105mph
pitbull784 is offline   Reply With Quote
Old 08-14-2010, 02:40 AM   #6
WB72
Before and After
WB72's Avatar
If they are rebuilt, that is a good price, I would pay that for them expecially since I know what a difference they made on my ride. When you do your top end, make sure you have the correct intake, because they are a totaly different fit than the originals. A mild cam helps out as well.
FYI, See if he will throw in the pushrods, you will need a different length than stock.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 08-14-2010, 11:25 AM   #7
bitchin85
bitchin85's Avatar
theyre different? i used my stock ones and they work fine.. i think.. what kind do i need?
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
