Old 08-14-2010, 08:10 PM   #1
menace121978
menace121978's Avatar
Lightbulb wiper motor question
i want a wiper motor without the pump on it. will the '73-'77 wiper motor work on my truck (78)? anyone done this? the summit web site shows the 77 motor looking like theres a cover plate or something that goes on it. here's the link...
http://www.summitracing.com/parts/AAZ-40-160/
also help me pick a brake booster and master cylinder!! thanks guys!!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-15-2010, 10:39 AM   #2
menace121978
Re: wiper motor question
anyone???
"Dennis the Menace"
Old 08-15-2010, 10:57 AM   #3
S10Fan
Old Heap Driver
I don't know!
Anyone??????
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 08-18-2010, 09:04 PM   #4
shenk10
shenk10's Avatar
I'm not sure about the wiper motor, but I like this booster and cylinder. It is pretty expensive though but looks really good.
https://www.brotherstrucks.com/prodi...number=KORN87S
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 08-18-2010, 09:17 PM   #5
ray_mcavoy
Hi Dennis,
The wiring is different on the 73-77 wiper motors so they won't be a direct plug-in fit on a 78 or newer truck. Also, the gearbox cover on those motors incorporates the washer pump ... you'd have to make a home-made cover to eliminate the pump on one of those motors.
GM changed over to the electric reservoir mounted washer pump on these trucks sometime around 85 or 86. I'm pretty sure the wiring on the rest of the motor stayed the same from 78-up. So an 86/87 or so wiper motor should fit your truck and eliminate the motor-mounted washer pump.
ray_mcavoy is offline   Reply With Quote
Old 08-19-2010, 09:09 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
Take a look at the 80's & early 90's S-10 wiper motor. Bolts up to the same mount points as the older ones but has an external pump and is very small. I don't have a pic handy but if you look up a 1990 S-10 truck on an auto parts store site it will show you one.
I have one I am making work on my 68 Camaro for extra valve cover clearance.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 08-19-2010, 09:12 AM   #7
68 TT
68 TT's Avatar
Found one.
Old 08-19-2010, 03:54 PM   #8
deepnsteep
How does the delay work on these if it were put in a new vehicle?
deepnsteep is offline   Reply With Quote
Old 08-19-2010, 04:21 PM   #9
68 TT
68 TT's Avatar
It is run off the control stalk on the steering column and the switch in the column just like the same vintage square body. There is also a delay module on the under side of the steering column as well.
I am working on a way to retrofit the delay wiper control switch into an older vehicle with a dash mounted rotary wiper control knob but it is pretty low on the priority list.
I am going to figure out the control wiring so it can be controlled by a standard two speed wiper switch without the delay feature and use one on my 67 K10 project.
