Old 06-14-2010, 07:33 PM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
Is this going to be a problem?
Recently purchased a 1964 K10 (stay tuned for the build thread) and while I am really impressed by most of the things the previous owner did, I have to question others. For instance, he created his own exhaust and routed it extremely close to the transmission pan. He did this because the transfer case mounts on the passenger frame rail, not giving enough room for an exhaust pipe on that side.
The pipe is so close to the pan I can't even get a finger between them. Is that going to be a problem with exhaust heat and the tranny temperature? He did install an Moroso aux cooler (second tranny cooler) on the frame, but I don't know if that's going to fix the other problem.
What do you guys recommend? Re-do the exhaust so it isn't as close to the pan, or will it even be an issue with a heavy aluminum pan and a second tranny cooler?
Jakes-66-K10 is offline   Reply With Quote
Old 06-14-2010, 07:54 PM   #2
lakeroadster
Re: Is this going to be a problem?
Wow, looks like the PO did some nice work.. everything looks clean and painted. For the exhaust I would wrap it with header heat wrap just in the area adjacent to the tranny pan. should be fine. No worries
lakeroadster is offline   Reply With Quote
Old 06-14-2010, 10:24 PM   #3
nicke
nicke's Avatar
looks very clean...lets see some more of the truck!
1965 Impala SS project Page.
My Wheels
Classic Nation
My classic car videos
nicke is offline   Reply With Quote
Old 06-14-2010, 10:42 PM   #4
Bulldoser65
I 2nd wrapping it with header heat wrap.
And that truck looks super clean.....Lets see more pictures of it.
Bulldoser65 is offline   Reply With Quote
Old 06-14-2010, 11:08 PM   #5
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Exhaust wrap will allow you to sleep at ease....I see no problems there.
Looks good so far !
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-14-2010, 11:10 PM   #6
robby5323
I would say that with the height of the truck, combined with the finned pan, you will have plenty of air movement over the area to not have any heating problems. Maybe a more shallow pan, or an aftermarket cooler just for giggles....
robby5323 is offline   Reply With Quote
Old 06-15-2010, 10:57 PM   #7
fryer1979
Redneck Hillbilly
fryer1979's Avatar
I'll go along with the header wrap idea, if the pipe being that close really makes you nervous. A lot of newer vehicles have exhaust pipes routing that close to stock trans pans with no heat shielding at all. You shouldn't have any issues, but if header wrap will help you sleep a little better... I gotta agree also; we need more picks of that truck, she looks clean.
fryer1979 is offline   Reply With Quote
Old 08-20-2010, 11:53 AM   #8
panelrodder81
Doin' it live!
panelrodder81's Avatar
Jake, I'm gonna need to see that truck up close now as that chassis looks really great!
I second the heat wrap but I have no actually experience with it, recommendation based on recommendations I've received. I need to get some for a similar problem. My exhaust was actually touching my shifter linkage, the shifter you sold me, when I first put it all on. But if I bend the hanger the pipe hits the frame mounted brake booster... sooooo, I'm gonna wrap it and leave it in the middle of the two obstacles. The gap between the pipe, the linkage, and the booster is only slightly more than the thickness of the wrap so we'll see how it works. I may make a spacer and drop the exhaust down a little too... but we'll see.
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
