68 suburban gas tanks/headers/4x4 parts/power brakes/carbs
I've got a set of Rancho 5000 shocks that I had on a Suburban with a 4" lift. Also have the front 4" lift leaf springs for it. Also have a 20 gallon Suburban/Blazer gas tank for sale (used- it needs a new sender), and 13 gallon auxilliary tank that fits behind the 20 gallon tank of the Suburban. It doesn't have a provision for a sender but makes a great backup tank when you're out in the boonies. Also I have the power brake setup out of my 68 'burb which had front disks/rear drums. I also need to get rid of two carbs. One is a Holley quadrajet, which was working fine when I removed it from my 'Burb, and a Holley 650cfm 4 barrel with vacuum secondaries and the zinc plated finish. And finally I have a set of used Hedman headers for a small block Chevy that will fit a 67-72 4x4. I need to sell this stuff (it's been cluttering up my garage for about a year now) so if you're interested send me an e-mail and make me an offer. I can send pics and more info upon request.
I snet you a PM. I would be interested in the 13 gallon auxilary tank. Where are you located and how much. Thanks.
Just sitting here contemplating contemplation. |
what are you asking for the burb/blazer tank?
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
![]() Join Date: May 2002
how much for the holley 650? does it have an electric choke?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
gas tank
I too am interested in the blazer/burb tank. After 73step. let us know where you are located.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
headers
how much for the headers and where are you located?
troy wilson |
Registered truck nut
I'm interested in the lift and springs depending on your location.
MOUNT VERNON, WASH. STATE Need a part? Just PM me |
Im still interested in the auxilary tank....thanks
I'm located in the Phoenix, Arizona area. The Holley carb is partially dissassembled and does have an electric choke - $30. The Holley quadrajet is fully assembled and was running fine when I removed it - $75. The auxilliary tank is made of heavy gauge (for a gas tank) steel - $50. The headers need sandblasting and a fresh coat of paint - $20. The 4" front lift springs I think are a heavy duty type, and the shocks were installed in 1999, but have black paint overspray on them and could use a fresh coat of paint, and I don't have u-bolts or rear blocks to go with it - $75. The power brake booster setup with firewall bracket, M/C and prop valve has a new booster as of 2001 from NAPA and worked fine when I removed it - $100. The Blazer/Burb tank needs a new sender and has a dent on the bottom but it doesn't leak and I have the tank straps for it as well - $25. Let me know if you need any additional info or pics. I will ship this stuff wherever, provided you pay shipping costs. Again let me know if you're still interested. Thanks!
I PM'd you on the springs and shocks
I sent you a response to your e mail about the auxilary tank. Lets set something up. Thanks
