Old 03-17-2011, 04:08 PM   #1
Mikewb
harness question
am going to put a 5.3 in my 94 silverado. But was wondering if the motor will run using the factory computer or if i need the one that belongs to that motor.
Mikewb is offline   Reply With Quote
Old 03-17-2011, 04:14 PM   #2
Clyde65
Clyde65's Avatar
Re: harness question
you need the one that goes with the motor, also you will need to have the VATS taken off, vehicle Anti-Theft System before it will run more than 3 seconds.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-17-2011, 04:22 PM   #3
Mikewb
ok will the factory fuel pump work for this? and any other info or advice on what all ill need to do.
Old 03-17-2011, 06:22 PM   #4
Clyde65
Clyde65's Avatar
I dont think it will, the 94 had the old LT motor in there and I believe it required lower fuel pressure similar to the GEN I motors, you need one that can supply 55-58 PSI constantly. if you have one that pushes more, then a fuel pressure regulator will be needed.
Clyde65
Rebuild of Clyde
support our troops!
Old 03-17-2011, 07:13 PM   #5
Mikewb
is there a certain year motor that is higher horse? or they basically the same?
Old 03-17-2011, 10:36 PM   #6
clinebarger
A 94-96 B-body (Caprice, Impala SS, Roadmaster) fuel pump will fit your sender & deliver the correct pressure & volume.
clinebarger is offline   Reply With Quote
Old 03-18-2011, 12:42 PM   #7
Mikewb
ok thanks
