Old 09-21-2010, 10:58 AM   #1
DT1
DT1's Avatar
Going To Do Some Major Rebuilding. Need Sources
71 C-10 350/350 Q-Jet
I'm pulling my engine, and transmission out of the 71 this weekend and will be rebuilding everything stock.
While I'm at it, I'll also be rebuilding my Rochester 4bbl.
Can you guys suggest a quality, full engine gasket set, transmission kit and carburetor rebuild kit. I've had problems with inferior stuff in the past and I really want to avoid it this time. I've always used Felpro Perma Torque gaskets with good results but one of the ongoing problems I've had is with the valve cover gaskets leaking. It also seems that there are a lot of bad carburetor kits out there.
Thanks for any suggestions!
DT1 is offline   Reply With Quote
