Still plays with trucks
NP205 shifter boot alternative
The shifter boot on my NP205 was shredded and let in a lot of noise and smell so I had been looking for another one for a while. Never could find one used that was the same as mine and I can't justify spending $30 plus shipping on a new one.
I was looking for a leather third gen F-body manual trans shifter boot to use like I did on my 68 Camaro to adapt a ratchet shifter to the stock floor console but couldn't find one. I happened across a wrecked Saturn with a manual trans and it had a similar leather shifter boot to the F-body part but it was on a rectangular plastic retainer and the size matched the NP205 boot footprint exactly. I pealed it off the plastic retainer, cut the stitching in the corners to allow the edge to sit flat on the floor, punched the mount screw holes in the edge to make it clamp down with the NP205 boot retainer ring then drilled out the plastic shifter handle bezel in the top of the boot to match the NP205 shifter. Fits great, looks like it belongs and cost all of $3.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
Re: NP205 shifter boot alternative
You could replace the transmission boot with one from a mid or late 80's model truck and the look would be pretty similar.
Andrew 1987 V20 Scottsdale 383 TBI, SM465, NP208, 14FF, 4.10 1988 C1500 Scottsdale 305, 700R4, 3.08 1986 K30 Custom Deluxe 6.2, SM465, NP205, 14FF, 4.10 |
I hadn't thought about that. I will keep my eye out for one. Thanks for the tip.
