Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 10-19-2010, 07:13 PM   #1
Ronnny
installing hei
What is the easiest way to get the 12 volts on start and run for the hei dist. I was told just run a wire off the seloniod for the starter. Not looking for pretty just quick and easy.
thanks
Ronnny is offline   Reply With Quote
Old 10-19-2010, 08:25 PM   #2
fixit-p
fixit-p's Avatar
Re: installing hei
What year, make and model? all you need is a switch ignition source, no need to go to the starter.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 10-19-2010, 09:22 PM   #3
Ronnny
Re: installing hei
It is a 68 long bed. Someone had already put an altenator on it so it does not have a generator/regulator. has a (i think) 77 350 with the dist. fro the orginal motor. I read that i should be able to run down and take the resister out of the wire that goes to it now. I know some had it on the fire wall but do not see a ceramic one there like i have saw on other trucks. I just figured someone else could tell me the easyway right off. I have the wire where i can run one striaght from the switch i guess but someone could tell me how to do it the better or easier way. Was planing on doing this in the morning.
Old 10-19-2010, 09:39 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: installing hei
Most guys just run it from the ignition unfused terminal on the fuse panel. That's a key on source and is easy to run. 12 gauge wire is what to use. Some say 10 but that's overkill. You can run a fuse inline if you are worried about it.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-19-2010, 09:44 PM   #5
Ronnny
Re: installing hei
Just find a wire that is hot off of that terminal. I would hate to stick a wire under one end of the fuse i supose. I could look at the color codes on the wire diagram i have and see pretty easy i guess.
Old 10-19-2010, 10:11 PM   #6
fixit-p
fixit-p's Avatar
Re: installing hei
Vettevet was referring to the ignition unfused port on the fuse block shown in pic #1
Alternately you could eliminate the resistor wire shown in pic 2 and replace it with a new wire just depends on your skill set.
Old 10-19-2010, 11:46 PM   #7
Ronnny
Re: installing hei
Ok the pictures help a lot. I can do about any of it but car wiring is not my normal thing. My truck has a lot of unused and cut wires already to clean up as i feel like it and will replace a few. Just a lot of stuff is easier with people like you to give a little guidence to us that this is not our specialty but an interest. Since i work in industrial machines i can do this but it does not always come out as nice as a person that does or has done it a little more regular. Thanks alot for the help.
