Clutch Issues...
Hello all, sorry this is my first post, and not in the introduction part, but I have a problem that is stumping me. One of many trucks I have is a 1974 K20 with a 292, SM465, NP205, and so on and so forth with the heavy duty 3/4 ton stuff. Last weekend as I was driving it to my farm to trade trucks to go back to school, I noticed it was slowly getting harder to get into gear while shifting, to the point I had to actually slam it into gear. Then it got to the point I had to start the truck in gear to move it. I made a longer rod for the clutch release lever, and put it in tonight. Even with the longer rod, it didn't make a difference. The clutch will not disengage at all. The only way to start the truck without it moving is to have it in neutral. And then I can't get it in gear. Checked bellhousing bolts and they're all tight. Adjusted the rod a bunch of different lengths, to no avail. Seems to me to be a problem most likely with the pressure plate.. Have any of you had this happen? Or could it possibly be the clutch plate managed to get stuck to the flywheel while driving? The pedal has plenty of feel like I'm moving something, but its hard to tell whats moving and whats not.. Thanks in advance guys.
Re: Clutch Issues...
sounds like the pressure plate has messed up.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Only one way to find out for sure what's going on. Drop the trans. If all the linkage looks good under the truck and fluid level is good in trans. Then most likely pressure plate is bad.
Got same tran Can you shift it ok with out the clutch when moving or if setting still shut off shifts ok clutch problem
When my granny did that, the clutch just needed adjustment, but you say you did that. I need about one inch showing past the adjustment nut on the threaded rod on my truck. My nut worked loose on the rod - there is a wave washer that should be there. I am assuming that you have a mechanical clutch. I would adjust the nut all the way and see if it makes any difference.
Check the clutch release lever. Sounds like it gave way. Crawl under and have someone operate the clutch. pop the bellows on the clutch lever so you can see in.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
