66 327 carbs .....
Greetings Ya'll !
I have a question for the forum that I hope someone can answer. on a 66 chevy c10 with a 327..... can anyone tell Me what model/brand/part number 4 barrel carb was stock on it ? Thank you for reading this and any help you can offer ![]() Randy Last edited by 63 & 64 Bowties; 11-17-2010 at 05:46 PM. Reason: WTB by non-subscribing member |
Re: 66 327 carbs .....
Probably had a wcfb carter on it. Look on ebay for one.
My truck came originally with that set up. Unfortunately it is long gone. But i believe it was a Rochester WCFB 4bl. The air breather on my truck was an oil bath type. It's still with the truck. Hope this helps.
Or it could have been a Carter!
I would adv. getting a 66 shop manual then all you would have to is to turn to the right page and it is right there. 4gc. 7025125 unless it as ca spec. then it would be 7036125
ron |
60-66 Nut
I'm not sure of the correct designation, but I'd say it may be a Rochester Four jet. That is what came on the 300hp 327's in the '65 & '66 Impala's
Real Projects never die
ive got an all original 66 327/granny 4 truck right outside and dad knows what carb is on it, i will try and ask him when hes off work tomorrow night, but a Rochester sounds right.
Ill put it this way, ive got a few lawn ornaments ![]() ![]() My name tag says Ryan KansasTwister On other forums
but they weren't 300 hp in the truck. the 4gc(rochester) above nbr is the carb( I also have one)
ron I don't know about the 65-66 300hp but I do remember that a 64 300hp took an AFB |
I've got a '66 327 in my '64. It has a 2bbl Rochester 2GC.
Q
'64 K20 327 |
66 327 trucks got a rochester 4 jet with a manual choke, but not all the 4 jets were made by rochester, evidently carter made some of the rochester 4 jets back in the day, straight from dads mouth, and hes been around hundreds of these 327s. I can get pics of our 66 if you wish to see the carb/air cleaner.
![]() Join Date: Oct 2009
my shop manual matches what Walt is saying - only carbs listed in my 66 supplement shop manual are as follows:
Roch B (for 250 and 292 with A.I.R. sys) Roch 2G (for 366 and 283 with A.I.R. sys) Roch 4G (for 327 with A.I.R. sys) - says the 4G was a mid-65 release. Carter YF (for L6 engines) |
Hello Walt ! Thank you for responding to My question. Iwould really like to see a couple of pictures of the air cleaner assembly if you dont mind sharing them.I honestly have no idea what they look like for that year. I am working on this truck for My brother who is a disabled veteran. My car that I am working on is entirely different than what I am doing for him lol. Anyway .. would love to see some air cleaner pics please! And thank you VERY much !
Randy |
