Old 11-19-2010, 05:53 PM   #1
dyrt
Changing driveshaft bearing type, replacing driveshaft
Howdy people,
My 69 c10 longbed originally came equipped with an inline 6, 3 speed, and the smaller driveshaft bearing(bolts are front to back, not side to side.) This means it also came with the small diameter driveshaft. I am installing a 6.0 and 4l60e so i want to change to the larger style bearing and larger diameter driveshaft. Doesy anyone know of a good donor truck for the larger driveshaft? Also, i need a bracket for the heavier duty bearing. I have seen one that hangs from the top of the trailing arm crossmember(so the bearing hangs down from it on the back side) and one that bolts to the bottom(so the bearing is essentially inside the crossmember) while looking at pictures in threads all over the forum. Are there two different brackets for a reason or did someone just bolt a later bracket into a crossmember and use it? Can anyone with any experience in this swap chime in?
Mike
dyrt is offline   Reply With Quote
Old 11-19-2010, 06:08 PM   #2
john
member #16
john's Avatar
Re: Changing driveshaft bearing type, replacing driveshaft
I had a 1970 BB truck with the bearing hanging from the top w/ side by side bolts.
john is offline   Reply With Quote
Old 11-20-2010, 05:14 AM   #3
raycow
The 4L60 is longer than your 3 speed. Would you consider changing to a one-piece shaft and fixing the bearing problem forever?
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-20-2010, 08:03 AM   #4
dyrt
i don't recall the length difference being that much, and as far as i know the 4l60e is the same length as a th350 which used a 2 piece in a lwb truck, so i plan on sticking with that, but i had thought about it.
Mike
Old 11-20-2010, 08:50 AM   #5
Shyguy
Junior Member
Shyguy's Avatar
I had a '67 3/4 ton with a L6 and 4 speed truck transmission. It came with the heavier duty drive shaft and the heavier duty carrier bearing mounted at the bottom.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-20-2010, 07:38 PM   #6
dyrt
That just seems odd to me, i can't imagine a reason why they would have mounted the same bearing two different ways. i wonder which one is easier to copy out of flat stock because i am going to have to choose and fab on up.
Mike
