Old 09-21-2003, 04:04 PM   #1
Paulgs71
steering column
I found a steering column I want. It has cruise. My truck doesn't.
My truck has the delay (pulse according to wrecking yard) wipers.
Questions:
If the column I buy has cruise will the wiring work?
If the wiper system is different will it work?
Are all steering wheels the same for 84-87?
(the one I found doesn't have one and mine is screwed up)
I am assuming NO. But you never know.
Paulgs71 is offline   Reply With Quote
Old 09-21-2003, 07:36 PM   #2
bigd65
bigd65's Avatar
the cruise wiring is seperate i believe. mine had it but someone cut the wires at the turn signal lever, so i pulled it all, even the wires from the steering colomn. then i found a lever with only the delay wipers and no cruise and all black.
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 09-21-2003, 07:52 PM   #3
Paulgs71
cruise control
The cruise on another one I saw is part of the turn signal as opposed to a seperate add on.
The wrecking yard said the wiring isn't compatible.
But they are not alway right.
I hate to bid and win one if it is the wrong one. Unfortunately the bidding will probably end before I know for sure. ( 1 hr from now)
The other problem is
I don't know for sure if this truck was originanly equipped with cruise. This may be a replacement column. It is a silverado C30.
The tag mentions intermitent wipers.
And convenience pkg code z?6 .
Does anyone know what the code is forcruise control or if it is included in the convenience pkg?
Any help
Old 09-21-2003, 08:07 PM   #4
rage'nrat638
rage'nrat638's Avatar
check your gen. message post
rage'nrat638 is offline   Reply With Quote
