Old 12-08-2010, 10:27 PM   #1
mighty_mike015
4l60e prnd
What is the connector on the left side of the transmission that is labeled in wiring diagrams as PRND A, B, C, P actually used for? Used ltswap.com for pulling wires from my harness and this whole connector isn't used. My thought is that it might output a signal to the computer when it is the positions Park, Reverse, Neutral, or Drive like a neutral safety switch. If I am using the 4L60E transmission should I put these back in?
Thanks,
Mike
mighty_mike015 is offline   Reply With Quote
Old 12-08-2010, 10:33 PM   #2
tonypaul
tonypaul's Avatar
Re: 4l60e prnd
yes its your neutral safety switch. I would recommend wiring it up...
tonypaul is offline   Reply With Quote
Old 12-08-2010, 11:08 PM   #3
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: 4l60e prnd
I eliminated it and used the stock neutral safety switch in my truck, an 87.
The purple output wire from the truck runs to the starter and functions just like stock, so no need to complicate matters. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 12-10-2010, 01:53 PM   #4
mighty_mike015
Re: 4l60e prnd
Thanks for the response fellas.
Old 12-10-2010, 11:41 PM   #5
tonypaul
tonypaul's Avatar
Re: 4l60e prnd
Only thing to keep in mind is if your plan on using a aftermarket steering column (ie- chrome) sometimes they do not have provisions for reverse lights. You will need to make sure if you do away with you neutral saftey switch you can still have a way to hook up your reverse lights....
